What should I use for footings.... |
Scott B
Orange Level Joined: 14 Sep 2013 Location: Kansas City Points: 1002 |
Posted: 02 Mar 2019 at 6:22pm |
Think I'm going to buy 2 of those 20' shipping containers for storage. Going to place them 16' apart and span a roof across for boat covered storage. Then add 8' open lean-to's off each end.
My big question is what to place under the containers for a footing? Been thinking of 24" perimeter concrete, around 12" thick. Add rock, gravel, etc in the center. Ultimately I want to get a skid steer and use one of the containers to lock it up...that would be the heaviest item that would go in. What have you all done? |
D17 Series 1
Allis B- 1939 Allis B- 1945 |
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21662 |
Unless your footings go down BELOW the frost line( 4 ft up here..) just remove all top soil, pack the bejeebers out of the subsoil, then keep adding crusher run(or whatever 'compactable fill is called) 6" at a time and whack the bejeebers out of each lift. I do under the cans AND the 'boat storage area'. Done right ,it'll outlive you and me. As for the roof, consider where the rain and snow will pile up ! Maybe use Google to see what others hve done in using seacans. I wish I could use them but city says building permits ($$$) are required !!! |
Thad in AR.
Orange Level Access Joined: 12 Sep 2009 Location: Arkansas Points: 9301 |
12 to 16” footers down to the frost line.
Will you span the roof to the outside of each container? Wondering if you could find some cheap chicken house trusses for the roof. |
LeonR2013
Orange Level Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Scott put your footing in the light of the moon as suggested by the Farmers Almanac. Believe it or not they will not sink and everything stays level.
shameless dude
everyone around here just lays crush rock down about a foot thick and sets the containers on it. myself, i'd prolly put some concrete pillars down too.
Scott B
[QUOTE=Thad in AR.] 12 to 16” footers down to the frost line.
Will you span the roof to the outside of each container? Wondering if you could find some cheap chicken house trusses for the roof. [/QUOTE ] I've seen those chicken trusses down your way. They'd sure work if I could find some but probably would need to travel a ways to get them. I am spanning to the outside. |
D17 Series 1
Thad in AR.
Just curious how wide one of these containers is? I’ve been seeing lots of 32 and 40’ trusses for sale. Where your biggest span is 16’ between the containers I would just frame it up. |
regular seacans are 20 long, 8 wide, 8 1/2 tall so... seacan....boat....seacan 8..16..8 32' wide overall friend used one to store Ford3000 in one end,kinda tight( 7'6" +- inside) and watch your head when getting onto the tractor !!
not mine, found on google.....
DanWi
Orange Level Access Joined: 18 Sep 2009 Location: wttn Points: 1709 |
Just an idea, if you had a a 48ft truss you would already have your 8ft lean-to's on each side and you would have one continues roof over it all.You may have to do a little reinforcing on the truss depending on how it is designed because the truss would be sitting on the bottom chord on top of the containers. I would even go 10 or 12 ft wide on the lean-to for a little extra space. Trusses on top would give you full container height in the lean-to. If you had a backhoe to dig a trench and equipment to handle them use 2x2x6 or 2x2x3 jumbo cement blocks for footings they can be got fairly cheap, we helped a neighbor put a post in an old wood shed on his farm and used a 3ft block to set the post on all involved thought that was a good idea in that case.
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4377 |
Here the 40 footers are the most common. But they have been advertizing even longer ones the year or two.
The one I used for vineyard supplies and chemicals just sits on a railroad tie on each end. Been there close to 20 years now. Used a tie in front of the door as ramp to drive the ATV in on.
Alberta Phil
Orange Level Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3661 |
I've got two 40 footers and a 53 foot all on either good railway ties or treated timber 6x6s. One timber across at each end.. been that way for years and haven't moved even thru our freeze/thaw cycles every year.
Scott B
That’s what I’m aiming for Jay. Except want more pitch on the roof and then another 8’ on each end |
D17 Series 1
Scott B
I was thinking that for a bit. But think I’ll anchor in the span with shorter trusses and have them a bit higher than the containers. Then lower down a bit in the lean to’s |
D17 Series 1
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78275 |
YEA, I would make 16 ft trusses to set on edge of the connex and span to the other... then I would use 16 ft rafters to span 8 ft over the connex, then 8 ft out for the lean to. You don't have to make it one complete 48 ft truss.... Easier to work with 16 ft sections.
thendrix
Orange Level Joined: 04 Feb 2013 Location: Fairmount GA Points: 4746 |
Watch those chicken house trusses. A lot of them that have been up for 20 to 30 years, especially in the older houses that stayed wet inside, will be warped and twisted and they're hard to use. We can buy them new here for $175 for a 40 ft or $225 for a 50 ft. They have a 5/12 top pitch and 3/12 bottom pitch
Dakota Dave
Orange Level Joined: 12 Sep 2009 Location: ND Points: 3899 |
We used them in the desert in the military all we did was build up a area a few feet bigger than we wanted and placed them directly on the packed sand. as long as you had a slop away from them you never had a problem. in the desert we just spanned a flat roof over the containers 20 ' between and left both ends open. when it rains in the desert if you don't have drainage you really regret it. we put carpets and furniture on the packed sand. with the ends open and the air space between the container tops it stayed bearable. Our containers had side doors cut into the walls.
Scott B
Are those wood I assume at that price? Most takedowns I've seen have been steel..... I might stop by a Truss Mfg. and see what they'd costs......Thinking 4 would easily cover my needs.
D17 Series 1
thendrix
Yes these are wood. They're chicken house trusses. They're are 2x6 top and bottom cord. For chicken houses they're set on 4 ft centers
Edited by thendrix - 04 Mar 2019 at 10:58am |
NomoreJohnDeere
Silver Level Joined: 24 Jul 2017 Location: Missouri Ozarks Points: 308 |
There is a guy on Arkansas cl that sells chicken house take downs
Metal trusses if I remember sells in 40 ft sections, no sides |
HD3
john(MI)
You are gonna need both of them level and level with each other. They normally sit on the four corners. I would get sona tube and put in eight piers. If you come up a little above grade it should be easy to level them. A laser level would be easiest. Then you need to get them squared up, probably use sticks and strings and the 3-4-5 method on the corners. If you could get them set so the corner sits in the center of each pier I don't think they would ever move. You will also probably need to cover the under side of the trusses so you don't get white spots all over your boat!
shameless dude
could check with "perka buildings" out of st joe MO.
Calvin Schmidt
Orange Level Joined: 11 Sep 2009 Location: Ontario Can. Points: 4515 |
If you are using crushed rock and have good drainage, you don't have to be concerned about frost.
