125 air to fuel ratio
Super B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Super B Quote  Post ReplyReply Direct Link To This Post Topic: 125 air to fuel ratio
    Posted: 02 Mar 2019 at 6:49am
Would anyone know the air to fuel ratio a 125 motor would like like?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Super B Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2019 at 6:52am
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2019 at 7:43am
14.5:1.  Same as all gasoline engines.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Super B Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2019 at 8:11pm
I was told there were differences. Sorry
mjbower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mjbower Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2019 at 7:46am
What is that in? I'm curious that's cool awesome engineering work on that manifolds.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Super B Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2019 at 8:02am
Its in a old family b I am retro modding.it kind of got out of hand.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Super B Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2019 at 8:28am
It has been my lawn mower for 35years or so.now its going to have some fun.
Edited by Super B - 03 Mar 2019 at 8:30am
Post Options Post Options   Thanks (0) Thanks(0)   Quote mjbower Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2019 at 7:04pm
Wow that's awesome. Beautiful sheet metal work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2019 at 8:01pm
NICE LOOKING UNIT !!!
From GOOGLE-----------
The ideal (theoretical) air-fuel ratio, for a complete combustion, is called stoichiometric air-fuel ratio. For a gasoline (petrol) engine, the stoichiometric air-fuel ratio is around 14.7:1. This means that, in order to burn completely 1 kg of fuel, we need 14.7 kg of air. The combustion is possible even is the AFR is different than stoichiometric. For the combustion process to take place in a gasoline engine, the minimum AFR is around 6:1 and the maximum can go up to 20:1.
When the air-fuel ratio is higher than the stoichiometric ratio, the air-fuel mixture is called lean. When the air-fuel ratio is lower than the stoichiometric ratio, the air-fuel mixture is called rich. For example, for a gasoline engine, an AFR of 16.5:1 is lean and 13.7:1 is rich.
In the table below we can see the stoichiometric air-fuel ratio for several fossil fuels.
FuelChemical formulaAFR
MethanolCH3OH6.47:1
EthanolC2H5OH9:1
ButanolC4H9OH11.2:1
DieselC12H2314.5:1
GasolineC8H1814.7:1
PropaneC3H815.67:1
MethaneCH417.19:1
HydrogenH234.3:1
Edited by steve(ill) - 03 Mar 2019 at 8:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Super B Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2019 at 8:07pm
Thanks for help
Post Options Post Options   Thanks (0) Thanks(0)   Quote Super B Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2019 at 8:10pm
The hood was made by a neighbor of mine. He is a craftsman. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2019 at 4:36pm
Did you make the cab from scratch, or was it on something else ?  Size looks good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Super B Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2019 at 7:41pm
[IMG]upload
Edited by Super B - 04 Mar 2019 at 7:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Super B Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2019 at 7:58pm
Dad had this cab on a wd45 in the 50s or late 60s.it was built by automatic out of pentor Nebraska as a kit cab.i believe it is blue ox now and is still owned by the same family it fit Wright on kind of
