snap coupler turning plow
Rod5300 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod5300 Quote  Post ReplyReply Direct Link To This Post Topic: snap coupler turning plow
    Posted: 29 Jan 2019 at 4:11pm
I have found a 2 bottom plow that would fit my D 14 I don't really need it as I have 3 point plows to use but just like to have it for my 14   the plow seems to be in good shape but the hitch that fits in the snap couple bell is gone. How hard to find one of these and do they just bolt on.
I thank you for your comments on this post.
Again thanks
Rodd
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod5300 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 7:30pm
I figured to have some allis folks give me some insight on my plow question by now. I will ask this second question the plow is a 2 bottom no idea what tractor it was used on. I hoping it will fit my D 14
Again thanks for any help with these questions
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 7:36pm
Usually you can find one on eBay.  One is listed down, but a little high at $34.95.
Edited by Larry in NC - 29 Jan 2019 at 7:39pm
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 9:02pm
Always helps to post a picture in case there's something odd about the implement. But you should be able to put a two-bottom plow behind any tractor that will pull a three-bottom rig.
WC, CA, D14, WD45
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2019 at 2:31am
Yes you should be able to bolt the eye on the plow.  Just make sure the plow has the correct couplers for the latches. They are basically a Tee on the top.  Some times the pin going horizontally got broke and farmers would just stick a bolt thru the hole.  I believe there is a thread on Plows in the Knowledge base section, and it should have pictures.  That would probably answer most of your questions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2019 at 4:45am
Don't know what that's offa, but it is similar to a plow.  most plow eyes don't have slots, or that little flat bar, welded on.  also, there are different length eyes, depending on the final length wanted. Post a picture of the plow and we can ID what you need...
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2019 at 2:44pm
It would be interesting to know what that originally came on. Has a degree of adjust-ability to it. Not necessary for a plow, maybe why the high asking price?
I have one that is offset, never figured out what it was originally for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2019 at 7:57pm
That is interesting, I don't ever remember seeing one like that.  Somebody out here in Allis land knows what this one is for.
Yes, the plow one just has the two holes neither is slotted.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2019 at 8:22pm
I have wondered why A C  did not put a safety on latch of snap coupler.Could have put a spring loaded pin under hook and saved  there hitch .Dads plow flipped on D 14 and almost got him .Spring broke on hook. Had safety latches too.
