Toxic cookware
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Topic: Toxic cookware
    Posted: 14 Jan 2019 at 6:57am
[TUBE]0uATfA_WoTA[/TUBE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2019 at 7:42am
I agree that any pan with any type coatings could pose a health hazard to us! most all those advertised on TV to be slick and say that no food sticks to them are just pulling your leg, after buying any of them, they all say to spray with cooking spray before each use! that isn't shown on TV! I've seen those pans with worn off places inside and even some with chunks missing. some of that was possibly injested by someone! YUCK! i'd say...best would be cast iron, stainless steel, and some aluminum pots and pans. (just my observations)
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2019 at 8:05am
NO alumininum !!!!!
bad,bad,bad !!!
One of them metals that gets into the body and never ,ever leaves. Associated with several health issues,specially brain related. SAME reason you should NOT use 99% of the anti persperation  products( most are aluminum based)
best is cast iron and stainless steel.
ANY coating is bad..
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2019 at 8:47am
The pans should be named shumer--pelosi--reyanPigCensoredNuke
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2019 at 9:17am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2019 at 6:22pm
My favorite is red copper!
[TUBE]1oWHLaKPjps[/TUBE]
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2019 at 7:24pm
I have found that the best pan is the one my wife is using at any given time. Next question?😆
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2019 at 8:00pm
Im with Stan.......... don't have a CLUE what she is using... as long as the food hits the table on time !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2019 at 9:34pm
nella, thanks for posting this. My wife and I use mostly cast iron, some of which belonged to my grandmother and some stainless steel pots. We gave our granddaughter a starter set of cast iron for Christmas and she and our daughter will get all of ours when we can no longer use it. I have one aluminum pot I mix and start my brunswick stew in but I am getting a small cast iron "wash pot" for that.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2019 at 9:34pm
You means pans is for cooking with......? I thoughts they was just something for the ole lady to hit me over the head with. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2019 at 9:55pm
Darrel, you didn't train her right! One of those 6 or 8 inch cast iron frying pans will leave a nasty gash on your head if she swings it just right. Ouch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2019 at 10:22pm
Well Darrel,,,,,,,knowing you,,,,,she is using it correctly.  I'm just ah,,,,,,,um,,,,agreeing with you...
Love the new stainless, it heats so evenly, almost as good as cast iron.
The best thing about some GOOD, seasoned, cast iron is the cleanup!!  SOooo easy!
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 1:03am
When I was assistant leader of the scout group, once in a while, we had some toxic tasting stuff come out ta the dutch ovens. Didn't seem to hurt them too much.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 2:59pm
You forgot Wink Darrel was a little slow Wink in letting her catch him. LOL
This page was generated in 0.906 seconds.
