Can you ID this tractor? |
Page 12> |
timthetoolman ![]() Bronze Level ![]() Joined: 09 Jan 2019 Location: Middle Tennesse Points: 7 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Jan 2019 at 9:59am |
Hello all! This is my first post here. A buddy of mine called me about some land that had sold recently to a friend of his that was chock full of older equipment scattered all around the property. I got to go over with him and rummage around in hopes of finding a deal on a decent tractor. Long story short, I ended up with this tractor, and hopefully I can get her going.
I need to get back over to the property where the tractor is now that I know where the serial number is located and get that. In the meantime I'm wondering if you all can help me ID this tractor. Rear tires are 18.4-34, fronts are 10.00-16, has a 2900 engine with turbo. It doesn't appear seized, but I can turn the fan which turns the crank by hand. I'm a little concerned that it appears not to have compression, but I like projects. From what I have found online I think it's a 200. Any idea on where I can get parts and a service manual/parts book for this? What are the chances of finding a front end loader for this? This is my first Allis Chalmers, and I can't wait to get her running. Thanks in advance for your help!
![]() Edited by timthetoolman - 09 Jan 2019 at 10:00am |
Jordan(OH) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Celina, OH Points: 1545 |
190xt
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21733 |
re: It doesn't appear seized, but I can turn the fan which turns the crank by hand. I've never met a diesel I could do that to...even my 'ultra low compression' A-C forklift ! no valve stem in front tire, rear is flat and cracked, I bet rubber is $$$$ others who KNOW will reply,just wait an hr or 2.... Jay
I thought those were gasoline with no turbo? Did they come with the 2900 as well?
Yeah, I am with you on that. Was hoping maybe valves were stuck. I got it fairly cheap, but I hope I'm not the proud owner of a large boat anchor. Been looking into tires, hopefully I can find some used.
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29781 |
That is a 200
Wink I am a Russian Bot |
automaticdave ![]() Silver Level ![]() ![]() Joined: 20 Jan 2011 Location: Granton, ON Points: 220 |
I call it a 200 as well !
Tim NH ![]() Orange Level Access ![]() Joined: 16 Oct 2012 Location: Lancaster NH Points: 1066 |
200 look at the oil filters
TramwayGuy ![]() Orange Level Access ![]() Joined: 19 Jan 2010 Location: Northern NY Points: 11309 |
Broken crank, perhaps?
Ouch a busted crank !!I'd hate to see inside cause that'd do a LOT of damage.
I hope not! We couldn’t hear any odd sounds when we spun it. The bendix on the starter didn’t seem to be kicking it when we tried to crank it. And it was spinning pretty slow. I suppose I can go take the valve cover off and see what happens when we rotate it before I go get rubber. Any other advice on checking for a broken crank?
Put tractor into neutral, engage the PTO and manually turn the PTO shaft(say with vice grips or pipewrench) the crankshaft HAS to turn, see if front pulley and fan turn as well. Odds are good ther'es a HUGE 'mousehouse' or condo in the bellhousing/starter area. My first D-14 was PACKED !
Fred in Pa ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9128 |
Jay This tractor has a HYD. PTO .CLUTCH ! Be a bit hard to do that .
A-C_220 ![]() Bronze Level ![]() ![]() Joined: 05 Jan 2019 Location: Canada Points: 91 |
I could tell the crankshaft was broke on my 220 because I could move the pulley mounted on the front of the crankshaft up and down with the fan belts off. I could probably move it so easily because it was broke right before connecting rod #1. Looks like a good project, I like the canopy on it.
Edited by A-C_220 - 09 Jan 2019 at 2:56pm |
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 11613 |
Looks like it has an upgraded "SI" series one wire Alternator on it. Somebody got rid of the old "DN" series Alternator that was on it. They probably disconnected or done away with the VR to..... Steve@B&B
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8197 |
Welcome to the forum.
Funny thing I'm watching home improvement now |
tbran ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Paris Tn Points: 3260 |
yup you have a 200 - and by the looks/sound of it you will have a long time before you need the next project to undertake.... or tighten the lug bolts...
bradley6874 ![]() Orange Level ![]() Joined: 05 Sep 2010 Location: salisbury md Points: 1344 |
Ok looks like a 200 more pictures please what's the deal with the grill never seen the top look like that. Also what other equipment is laying around in front of the tractor is something snap coupler all so something orange in the background. Ps welcome aboard
Ky.Allis ![]() Orange Level ![]() ![]() Joined: 31 Jan 2010 Location: Kentucky Points: 984 |
I agree it appears to be a 200 or what's left of one anyway. Hope you didn't pay any more than scrap price. My advice to you is to start drinking heavily.
Unit3 ![]() Orange Level ![]() ![]() Joined: 17 Oct 2009 Location: NC Iowa Points: 5504 |
200 for the black gauge hood. I'll take the weight bracket and bolts. The canopy is a good little find.
LionelinKY ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Radcliff,KY Points: 695 |
190 gas was 265 CID
190XT gas was 301 CID 190 diesel was 301 CID 190XT diesel also 301 CID with turbo added
200 really just the last incarnation of the 190XT before the 7000 series came out
Dual filters are a good indicator that you at least have a 200 engine-no 190 had dual filters from the factory. Serial # is the only true way to tell what the tractor is.
I almost think I can make out the #200 on the hood decal.
hyd pto clutch.... dang fancy NEW tractor stuff...... ![]() what'll they think of next ?? |
darrel in ND ![]() Orange Level ![]() ![]() Joined: 22 Nov 2009 Location: Hebron, ND Points: 8596 |
If you can get that tractor whipped into shape, you'll have a dandy tractor there. I hope it pans out to be mechanically sound for you and only needs cosmetics. Darrel
Well, I stopped by and got the serial. It's 200 8877. Making it a 200, and also from 1974. Thinking I could fix just about anything that could be wrong, and with the advice of a couple other guys that seemed to think it could be operational fairly cheap outside of rubber, I paid $1500 for it. I'm not sure if it's good or bad, but it wasn't far from scrap price. Obviously the weight range for a 195 - 220 is pretty big, and I wasn't sure what model it was.
Based on the input here, assuming the crank is broke I went in search of a crank in case that is the issue. No luck so far, but I haven't dedicated a ton of time to it. I suppose I could pull of the valve cover and turn it by hand to see what moves, or doesn't. I could also get the starter working and try to turn it over. That should tell the tale. Any advice on where to source parts? And just for fun what are your guesses on how much it will cost to get it back running? Maybe best case / worst case? This ought to be interesting. The guy I got it from may let me walk away from it and I'd like to know if that's a good idea or not. If the parts are out there and semi-reasonable, then I'm down for a challenge if I'm ultimately ahead money on it. ![]() |
OK, I have zero knowledge about the 200 but...$1500 for any nonrunning tractor is a tad steep. You already KNOW there's 'something wrong' with the engine. Sadly you could dump another 1500 into getting it to run and THEN find out tranny's shot, hydraulics leak, rad's toast.brakes ? aw who NEEDS the ??... yup a REAL moneypit. The guys here with 200s (and similar ones) are your best source of information. Have to ask, what will it be used for? Do you need the HP and size ?? Up here 1500 gets you an OK running tractor,maybe with an implement or two. I'd just hate to see you toss a LOT of money into it and not be happy. Jay
A lot of parts on the 200 interchange with the 190XT, and there are a lot of them out there as well as 200s so finding parts shouldn't be too big a deal. I think you paid a good price as long as the engine and rear end is good.
Page 12> |
