WC final drive seals.... |
BennyLumpkin ![]() Orange Level ![]() ![]() Joined: 22 Mar 2010 Location: Centre Hall, PA Points: 2657 |
![]() ![]() ![]() ![]() ![]() Posted: 01 Sep 2010 at 3:44pm |
how hard are they to find, and how hard are they to replace?? my WC sat quite awhile before I bought it and I have been running it quite a bit and they leak terribly now.
Central PA Allis Express
1934 WC254 1945 WF 1945 WC135755 1951 WD68085 1953 WD45-150217 1957 WD45D-230744D B110 |
Gary in Texas ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Burkburnett, TX Points: 630 |
call Brenda, at Sandy Lake Imp. I got my WC seal from her.
Sponser of the site.
Take a little effort to get the pinion shaft out to replace that seal, but not too bad a job.
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22823 |
When I read "final drive seal" I think of the big cork seal for the wheel hub. Rubber replacements are available for these from AGCO and all you have to do is pull the wheel off and remove the seal retainer. Last I heard they were $30 or so apiece.
I havent pulled the wheels to see which seal it is, but oil all but runs out of them now.
The seals on the pinion shaft would let differential lube or final drive lube get on the brakes and run off would be higher up than the wheel hub seal leaking.
if it is the pinion shaft seals, there is a hole in the bottom front of where the brakes are, and it would leak out there.
if it is the big hub seals it will be all over the inside of the wheel and some on the outsida. Edited by Gary in Texas - 01 Sep 2010 at 8:02pm |
