WC final drive seals....
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Topic: WC final drive seals....
    Posted: 01 Sep 2010 at 3:44pm
how hard are they to find, and how hard are they to replace?? my WC sat quite awhile before I bought it and I have been running it quite a bit and they leak terribly now.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Gary in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 3:53pm
call Brenda, at Sandy Lake Imp.  I got my WC seal from her.
Sponser of the site.
Take a little effort to get the pinion shaft out to replace that seal, but not too bad a job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 4:01pm
When I read "final drive seal" I think of the big cork seal for the wheel hub. Rubber replacements are available for these from AGCO and all you have to do is pull the wheel off and remove the seal retainer. Last I heard they were $30 or so apiece.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 4:05pm
I havent pulled the wheels to see which seal it is, but oil all but runs out of them now.
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 4:19pm
The seals on the pinion shaft would let differential lube or final drive lube get on the brakes and run off would be higher up than the wheel hub seal leaking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 8:01pm
if it is the pinion shaft seals, there is a hole in the bottom front of where the brakes are, and it would leak out there.
if it is the big hub seals it will be all over the inside of the wheel and some on the outsida.
Edited by Gary in Texas - 01 Sep 2010 at 8:02pm
