CA wire harness |
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25548 |
Topic: CA wire harnessPosted: 17 Dec 2018 at 2:23pm |
anybody have an original CA wire harness in usable shape they could part with
I am still confident of this;
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 18 Dec 2018 at 2:02am |
If you just want to cobble something together, there are not that many wires to fool with. As for any of the wiring harnesses I've taken off, there is a good reason why I replaced them. However if you want first class at a reasonable price get one here. www.brillman.com The harnesses he makes for older things will match exactly what he finds to be original; the wires will be covered with a cloth spiral braid of the correct color with the correct tracer colors, along with the correct jacket type and color. They are in Mt. Jackson Va. I wouldn’t even think about going anywhere else for anything electrical. What he has for wiring harnesses is far superior than anything else that I’ve ever encountered. As far as I'm concerned to appease the Correct police, the Brillman harnesses will win hands down every time. He is even the wholesale supplier to some big name tractor parts distributors.
Edited by PaulB - 18 Dec 2018 at 2:48pm |
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25262 |
Posted: 18 Dec 2018 at 5:59am |
Frankly, I wouldn't be using a 50-60 year old wiring harness except as a template to make a new one. If one wire is 'gimpy' there's GOT to be 2 or 3 more ready to let loose gremlins ! See what Steve at B&B has to offer, if you're not OK doing it yourself. Jay |
Dave(inMA)
Joined: 12 Sep 2009 Location: Grafton, MA Points: 2400 |
Posted: 18 Dec 2018 at 9:39am |
I can add that Steve at B&B makes first class wiring harnesses. I've installed one on my WD45 - looks and works great.
Dave
WC, CA, D14, WD45
sparky
Joined: 13 May 2011 Location: So. Indiana Points: 1834 |
Posted: 18 Dec 2018 at 10:07am |
Ditto for Steve at B&B
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 18 Dec 2018 at 12:11pm |
Well Lou at this point looks like NO ONE has what you are looking for .Or no clue what you want it for . I do not have any used ones.
Edited by Fred in Pa - 18 Dec 2018 at 12:16pm |
LouSWPA
Posted: 18 Dec 2018 at 12:48pm |
I have a CA that I recently brought home. The overall appearance is really quite good for it's age, even to most of the decal transfer being present and in fair shape. But the wiring harness is in trouble. Now I can rewire it myself, if I just was looking for function. Steve is obviously my second choice, as he makes some really nice products, but I really was trying to avoid having the appearance of 'new' on the tractor, hoping to make it look original. Steve and I have already discussed rebuilding the generator to 12v, so it would look 'original'. Instead of a 'restoration' look, I am looking more for an original look.....as much as possible |
Gerald J.
Posted: 18 Dec 2018 at 1:45pm |
The shop manual available at: http://geraldj.networkiowa.com/Trees
in 9 pieces should have a good wiring diagram and information on the wiring harness. Gerald J. |
LouSWPA
Posted: 18 Dec 2018 at 1:56pm |
\ Thanks Gerald! what you sent me has a good wiring diagram. The diagram in the book is for a cutout rather than a voltage regulator. My tractor, a '53 has a voltage regulator, but I think I can figure that out. Lots of generic diagrams on line for GM style regulators |
Posted: 18 Dec 2018 at 2:48pm |
gee it's EASY to make a new harness look old... grab some mud, grease,oil splatter herea and there, rub in a bit, repeat until you get the desired 'look'... Jay
Alvin M
Posted: 18 Dec 2018 at 3:33pm |
the ca had a cut out from new some body changed it i can change any cut out to 12v
HoughMade
Joined: 22 Sep 2017 Location: Valparaiso, IN Points: 714 |
Posted: 18 Dec 2018 at 3:37pm |
The wiring harness on my B had all of 5 wires. I built one myself.
1951 B
LouSWPA
Posted: 18 Dec 2018 at 5:20pm |
ya, I agree, I can build it myself, done so on a couple of my WD-45, WD's. But, different connectors and insulation than originally used
and thanks for the cut out info! Edited by LouSWPA - 18 Dec 2018 at 5:21pm |
Gerald J.
Posted: 18 Dec 2018 at 7:14pm |
The cutout was used with a three brush generator that had current adjusted by the light switch so protecting the battery from over charging was a task for the tractor operator. Going to a generator with a regulator is a step more modern and forward and can significantly increase battery life. The regulator in an alternator is solid state and a bit more precise than the generator regulator so is better on the battery, and the alternator doesn't draw current from the battery at slow engine speeds like the generator with voltage regulator (that includes a cutout) or a cutout so the alternator cares for the battery even better.
Gerald J. |
Steve in NJ
Posted: 19 Dec 2018 at 2:48pm |
Lou, I can build you a new one and then go roll it in one of the many mud puddles we have outside, and then it'll look original...... LMAO!! Thanks guys for the kudos! Its appreciated! Steve@B&B
