37 A Tire sizes (New Tires) |
ZachD89
Orange Level Joined: 24 Dec 2015 Location: Littlestown,PA Points: 690 |
Posted: 02 Dec 2018 at 7:39pm |
I recently bought a 37 A that needs all 4 tires. I was just wondering what size tires others have on their A?? I was thinking of going with 14.9 28 on the rear and 7.50 18 on the front. Thanks
Edited by ZachD89 - 15 Jan 2019 at 5:57pm |
37 A,37 Waukesha B,35 WC,38 WF,M crawler,49 WF,49 WD,53 WD45,39 and 40 RC,47 WC,41 B,39 B,48G,48,C,59D10,D21,IB,B10,B12,B208,B1,Roto Bale Loader, sp100 combine, allcrop 66, L3 Gleaner
DaveWisc.
Orange Level Joined: 11 Oct 2009 Location: Wisc. Points: 966 |
Widen the back rims for 18.4x28 widen them on the outside works best. I really like mine at that size. The 7.50 are fine on the front sets level with this set up
JW in MO
Orange Level Joined: 16 Feb 2010 Location: South KC Area Points: 2599 |
Dave is right on with the rear tires, they came with 14-28 tires which converts to 16.9-28. I've had both, 14.9 and 16.9-28 on mine, I really like the looks of the 16.9 over the 14.9, I ordered new rims with the offset to the outside also.
allisrutledge
Orange Level Joined: 30 Mar 2010 Location: SurgoinsvilleTN Points: 1352 |
15 28 wards on mine but that may be a little hard to find. Same as 16.9. If you widen do as said or they will hit the belt pully
David Maddux
Orange Level Joined: 13 Sep 2009 Points: 2507 |
I have 16.9 on one and the old 15’s on the other one.
ZachD89
Mine has 11 inch rims so the 16.9 would probably be way to wide
Butch(OH)
Orange Level Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3831 |
How much work or money do you want to spend? My opinion is As look like
crap on OEM sized tires and even worse on the modern replacements for
that OEM size, but thats me If you want to keep the OEM rims and not
spend much for tires your stuck with 14.9-28s and tires that are all
sucked in at the the beads and look like they belong on a 25HP tractor.
Or you can widen the rims a little bit and up size to 16.9 and the tires
are still too small for a good looking outfit (in my slightly
opinionated opinion) The only way to make an A look right is on the old
15-28 tire which is 18.4-28 today. The pic is of my A on old 15-28s
with about 4" put in the rims. A modern 18.4-28 requires a LOT more in
the rims to get same look as different tire construction requires
different rim width. 18.4- 28s are also very hard to find. Another
option is to go with 18.4-30 and weld a spacer to the drop center so it
fits the wheel. They look real nice on a A. |
NEVER green
Orange Level Access Joined: 28 Feb 2013 Location: MN. Points: 6749 |
18.4 28 or the thirties like Butch said make the A look like a real tractor in my opinion. I have 18.4 28 on mine. |
JW in MO
Here's the A with 14.9's, same tractor with 16.9's. The 14.9's fit in the furrow better but I just couldn't stand the look, it deserved the bigger footprint!
john(MI)
I.M.H.O. The A with the wider tires look like the D21's Great Grandad.
ZachD89
Thanks for the replies everyone. I like the 16.9's a lot better than the 14.9's so I will be ordering 15inch rims and getting 16.9 tires. I will post pictures when I have the new tires on.
ZachD89
Here is a picture of my A before it gets the new tires mounted.
Fred in Pa
Orange Level Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9144 |
Not a bad looking A to start out with .
ZachD89
Here are pictures of my A with the new rims and tires. The 16.9 tires turned out good and looks good.
JW in MO
Looks good.
ZachD89
Thanks
