B & C tread width
Richmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richmar Quote  Post ReplyReply Direct Link To This Post Topic: B & C tread width
    Posted: 29 Nov 2018 at 11:36am
 B tread width question
Are all B rear tread widths  the same  or are the last B's  tread width same  as the C's
Richmar
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 12:19pm
Richmar,  With my father we sold the B for the life of the unit.
As to tread width's the basic one row B's are the same.  Yes, you can jiggle the wheels a bit by moving the wheels from side to side and setting the front wheels inside out but that is it.
However, there was a wide front B which had the dished rear wheels and the adjustable front axle.  You can easily recognize them with the dished rear wheels or the adjustable front axle.
The C was the B made for two row operation so the rear is wider and the standard C has a narrow front.  They did make a single wheel C and a wide front C.  The C rear wheels could be adjusted to the B width but the dished rear would make them wider.
If you have a B take good care of my favorite.
Good Luck!
Bill Long
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 1:05pm
Bill i have a sales book on your little B .Two B's mowing on front.Treads standard 40 1/2 to 52 1/2, adj axle 40 to 68.Have old spec sheet on old B and C.C tread was 52 to 80 .I have a 49 B i custemized, you may have seen it on these pages.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 1:54pm
At TractorData.com, the B dimensions page lists rear tread as 40 to 52 inches, and 40 to 60 inches. Does not note anything on either dimensions.
http://www.tractordata.com/farm-tractors/000/0/0/3-allis-chalmers-b-dimensions.html
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 2:21pm
Are you referring to the distance between the wheels, or the rim width and tire size?  They could be had with rims for 7, 7.50, 8, 9, and 10" tires with 9 and 10 being available and seemingly the only options starting at B18055 and I would assume all C's.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 2:31pm
Good point Aaron, and B18055 would be 1939.
txtractorguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote txtractorguy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 2:37pm
This may not be what you are looking for, but I'll submit and hope you find it helpful.
Rear Tires:  7x24, 7.5x24, 9x24 prior to tractor B-18055, 8x24, 9x24 or 10x 24 for B-18055 and up.
Front Tires:  4x15 standard, 6x16 special.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 2:55pm
Tread width is measured from center to center of tire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richmar Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 3:20pm
What I wanted to know ,were the final drive housing the same on all B's  even the last ones built.  I know the  rear wheels were different,  on the later B's they were same as the C's . Did they keep the final drives the same even though the wheels changed  .
Richmar
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 4:51pm
NO: Some of the final drives on the very late Bs has a flange axle like the C tractors to do away with the splined hubs.
 The Build a B project tractor that I have has this style flange axles. The earlier B that had the 5 bolt hubs still had the splined axle with a 5 bolt hub.
Edited by PaulB - 29 Nov 2018 at 4:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 5:59pm
From the AGCO ALLIS PARTS BOOK   page 144
Says 68' Rear Tread
More rabbit holes of info than carters little liver pills.
Edited by chaskaduo - 29 Nov 2018 at 6:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 3:58pm
From the parts book it looks like there was only 1 final drive casting.  It looks like at B #18055 they changed to the 5 bolt flanged axle.
AaronSEIA
This page was generated in 0.191 seconds.
