Battery Terminals
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: Battery Terminals
    Posted: 29 Nov 2018 at 1:58pm
My Ram 2500 (2008) has the chronic ability to get a black film on the positive terminal that requires monthly cleaning or it dies.
I've tried different remedies but nothing seems to work:
Coke
Terminal acid neutralizer
Electric Paste
Dielectric grease
Charlie
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 2:03pm
I coat my battery terminals with a product named WHIP. Bought it years ago at the national farm machinery show and have had good luck with it.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 3:06pm
Replace battery. It is leaking around the post. You can clean it up good and try some RTV between the post and the battery case and it might help.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
ihc pickups View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote ihc pickups Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 3:13pm
I will second the product WHIP. I likewise bought mine at a far show and it has worked for
me.
Mike
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 6:04pm
I scoffed at those green and red felt washers from Napa for years. Terminals on the minivan with all that electronic crap corroded like I have never seen, I tried the washers on a whim. Now I have them on all my batteries.
I've also taken an old timers suggestion and super glued a penny near each post.
Both worked well.
The mechanic always wins.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 8:33pm
Your post is leaking causing your problem, need a new battery.
I use vaseline, have been for years never have a problem, when I use it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 10:29pm
like Marv, I also use them little oily washers on most of my batteries, I have also sprayed WD40 on the terminals, but Charlie, your battery is fu-barred or soon will be. also there used to be a spray plastic sold in auto parts stores, in an aerosol can, after putting the cables on i'd spray it with that stuff and it would seal the whole thing until I took a cable off, that worked well, I also used that stuff on distributor caps and wires that were prone to sucking up moisture. I haven't seen it on the shelves for several years now, and the no know it alls at the counters don't know anything about it either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 5:56am
Thanks. Looks like a new battery is to be had.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 4:31pm
Di-electric grease - like used on AL wires will also help prevent the corrosion .
This page was generated in 0.184 seconds.
