D21 flywheel
Allisplumber View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisplumber Quote  Post ReplyReply Direct Link To This Post Topic: D21 flywheel
    Posted: 26 Nov 2018 at 10:34am
I’m looking for a new or very good used D21 flywheel, thanks for any help
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2018 at 4:17pm
Steel??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisplumber Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2018 at 5:07pm
Will be pulling farm stock class , but will be around 350 hp , 3000 rpms max , I know most all the guys I pull with still have the stock cast ones , steel would probably be the best way to go ?
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2018 at 6:46pm
If your taking the time to put one in, put in a steel flywheel. Even at 3000 and below.
Making a living farming with and working on Allis Equipment
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2018 at 7:00pm
You will sleep better at night with steel, wouldn t want to be libel for an injury or worse. I have a Rursch flywheel and 3 dick clutch, comes with rear engine plate slightly modified for low clearance bolts. Its for a 210, shaft same as a 21???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisplumber Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2018 at 7:35pm
Not sure if the shaft is the same but the d21 takes the same clutch as a 210 and 220 so I would think so , how much you asking for the one you have ? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2018 at 4:57pm
How close are you to the twin cities? Im 40 miles west.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisplumber Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2018 at 7:28pm
I’m east of Green Bay Wi , so your probably over 4 hours drive from me
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 4:17pm
Isshh ......... Just talked to Darrin and a new billet steel 12.5 crowler triple disc is 49, so 2500 sounds reasonable, at least I try to be reasonable. Just measured the shaft size it is 1 3/8.
Let me know watchya think, there is others interested.
Edited by NEVER green - 29 Nov 2018 at 4:20pm
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 8:24am
D21/210/220 can all use the same clutch when it comes to replacements. I think the D21 has more room in bell housing with the top mounted release fork though, when considering dual, or triple disc setups. I run a dual disc, and the casting bump where the release shaft passes through required some grinding.
