AC One-Sixty
Keepgoing View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keepgoing Quote  Post ReplyReply Direct Link To This Post Topic: AC One-Sixty
    Posted: 29 Aug 2010 at 1:06pm
We have an Allis Chalmers One-Sixty, I need to find the exhaust pipe. I can find the muffler easy enough, but am having a hard time tracking down the exhaust pipe and manifold. Can anyone help.
Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 1:23pm
Well, That's odd. I couldn't find a new one but I did find a used manifold for a One-Sixty.
It's on Ebay for $75.00 Buy it Now. Hope this helps. Jeremy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keepgoing Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 2:13pm
Thank you, I did see that on Ebay, what I haven't been able to find the the exhaust pipe that connects to the manifold. I will probably end up making one unless I can find one. Thank you for looking though. My next poject will be to fix the brakes. Currently it has none.
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 2:46pm
Good luck on the brakes. You probably already know that this tractor was made by Renault for AC. Brakes are a real pain to find. My neighbor has one.
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 5:22pm
I have been down this road Here is all the info you need you will need to go to a massy dealer for the part numbers to work The parts are for a massy 251 its the same motor as the 160 you will need the pipe extion to get the hight for the muffler to clear the hood.    manafold # 37781571  $125     muffler # 539523M92  $30  elbow # 1693855M1  $25   pipe extion 522584M92 $30   these were the prices in 2001  This will work for the allis you will always have better luck at a massy dealer for motor parts for the 160   its the same as a MF251 any questions on 160s just ask.  I have alot of ours driving and fixing them.   kip
160 CA 920diesel 5020 HD-3
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 6:02pm
That is very strange. My WC don't have the exhaust pipe and on top of that I really do need to get around to putting new brake pads on her also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keepgoing Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2010 at 11:55am
Kip,
Thank you very much for your help. that information is great. do you by chance have any pics of that setup you could either e-mail or post on line for me. I plan on calling the local MF dealer this afternoon and get today's prices. I will post them when I have them.
Thanks again Kip.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2010 at 7:07pm
Its the same as the factory set up its just 6 to 8 inches taller  plus it will sound better
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keepgoing Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2010 at 7:40pm
Hey Kip,
I called the local dealer today, here is what if found
Manifold 37781571 new part number 740221M1 $45.00
Muffler 539523M92 $30.00
Elbow 1693855M1 $20.00
Ext Pipe 522584M92 ???
I was curious as to why I needed the ext. pipe.  The elbow connects directly to the manifold and it appears the muffler connects directly to the elbow. The ext pipe pic appears to run under the tractor. is that correct.
Thank you Kip
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2010 at 7:51pm
I think I needed the exhaust up higher to clear the hood when you open it.  Plus Iam 6'9 I like the exhaust so it dont go back into my face.  I posted a photo of my 160 on here a few mins ago did you see it ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keepgoing Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2010 at 7:52pm
I didn't but I will look for it
