A Pepsi Challenge |
Dave H ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Central IL Points: 3591 |
![]() ![]() ![]() ![]() ![]() Posted: 31 Oct 2018 at 6:04pm |
I have four inch guttering. I need to punch a hole in it for another down spout. I have seen the tool to do this but i hate to do the 50 buck service call to have one punched in. How would you all go about this from a farmerized perspective?
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88415 |
air or electric grinder with a 4 inch cut off wheel.
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10830 |
Hole saw and compound aviation snips. Tracy
cwhit ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Sigel IL Points: 997 |
Hammer, chisel, duct tape. And probably a band-aid.
JC-WI ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: wisconsin Points: 34372 |
Shot gun, BLAM, hole made, now to finish with circular tin snips... if there's anything left
Grayray ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Ambridge PA Points: 3858 |
Draw out the area you want to cut out. Use an old beat-up wood chisel to punch a hole in the center then use aviation snips to cut it out. This is all I ever used when doing gutters and downspouts, I've done hundreds of them this way.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24766 |
Ask Shameless to redirect his 'machine'...there now you don't have to make another hole cause it's all covered with that white stuff he loves to share....... neighbour just upgraded his troughs from 5 " to 6", didn't know 4" was still around..you don't get a lot of rain ?? up here 'tin whackers' must have got their nickname by the way they install .Whack a screwdriver through the gutter, hack with snips,use 1/2 tube of sillycon to seal. The sad thing is I can use a proper die set in LESS time and do the job RIGHT. Jay
Well glad i asked, I m going to start with Tracy's suggestion with the hole saw. Why didn't I think of that? ![]() Thanks folks.
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12243 |
PERFECT!!!!
It appears on mine they just cut an X and folded the tabs down into the downspout.
