A Pepsi Challenge
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Topic: A Pepsi Challenge
    Posted: 31 Oct 2018 at 6:04pm
I have four inch guttering.  I need to punch a hole in it for another down spout.
I have seen the tool to do this but i hate to do the 50 buck service call to have one punched in.
How would you all go about this from a farmerized perspective?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2018 at 6:08pm
air or electric grinder with a 4 inch cut off wheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2018 at 6:47pm
Hole saw and compound aviation snips. Tracy
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2018 at 7:09pm
Hammer, chisel, duct tape.     And probably a band-aid.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2018 at 7:25pm
Shot gun, BLAM, hole made, now to finish with circular tin snips... if there's anything left LOL
Grayray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grayray Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2018 at 7:32pm
Draw out the area  you want to cut out.  Use an old beat-up wood chisel to punch a hole in the center then use aviation snips to cut it out.  This is all I ever used when doing gutters and downspouts, I've done hundreds of them this way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2018 at 8:43pm
Ask Shameless to redirect his 'machine'...there now you don't have to make another hole cause it's all covered with that white stuff he loves to share.......
neighbour just upgraded his troughs from 5 " to 6", didn't know 4" was still around..you don't get a lot of rain ??
up here 'tin whackers' must have got their nickname by the way they install .Whack a screwdriver through the gutter, hack with snips,use 1/2 tube of sillycon to seal. The sad thing is I can use a proper die set in LESS time and do the job RIGHT.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2018 at 8:21am
Well glad i asked,  I m going to start with Tracy's suggestion with the hole saw.  Why didn't I think of that?  Confused  Well maybe they re 5 inch,  I did not measure before I opened my pie hole.
Thanks folks.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2018 at 8:45am
PERFECT!!!!LOLLOLLOL
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2018 at 9:15am
It appears on mine they just cut an X and folded the tabs down into the downspout.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2018 at 1:13pm
That's the way the pros do it....
