7040
agpoorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote agpoorboy Quote  Post ReplyReply Direct Link To This Post Topic: 7040
    Posted: 23 Sep 2018 at 1:25pm
This is my first time posting, have followed this forum for many years.  I have an 8070, 7040, and a  W D 45.  All of them are work tractors.
The question that I have is on the 7040 when using the PTO and you shut it off it seems like it immediately goes to the braking position.  The implement that you are using comes to an abrupt stop.   The tractor does not allow the PTO to coast to a stop.  Is this normal? Is something out of adjustment?  Thank you for any advise.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2018 at 2:01pm
Yes, its normal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2018 at 4:03pm
About the best you can do is slowly idle the engine clear down and then disengage the PTO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote agpoorboy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2018 at 4:50pm
I was told it was normal. We do idle it down before we shut off the PTO.   I was hoping that there was a way to correct this problem.  Thank you for replies.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2018 at 4:59pm
Does anyone make a big slipper clutch to slide on the pto shaft?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2018 at 7:24am
If it is a big deal, the brake disc can be disabled so there is no brake. The downside to that is the PTO will always creep without being hooked up to something.  Choose what you want.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2018 at 8:14am
What Are you Uses The Pto For That It Is Problem
