heating suggestions needed
drak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drak Quote  Post ReplyReply Direct Link To This Post Topic: heating suggestions needed
    Posted: 15 Sep 2018 at 12:33pm
HI I hope every one is safe from the bad weather that I seen on the news, this winter I plan to do some restoration work to my wc, what I need is some sort of heating in my garage an need some advice as to what the best method, I am afraid to use some form without a naked flame like a log burner or lpg gas with all the petrol around or spraying with thinners, may be every thing could ignite and blow my garage up, all ideas ???Winkthanks in advance
John
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2018 at 12:37pm
Hot water heat with boiler outside.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2018 at 2:00pm
Hot water heat with boiler inside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2018 at 2:18pm
Well, you have to have some insulation to whatever space you have. I get by with one 1500 Watt 110 volt electric heater in my 20 x 24 ft garage. When it's really cold, I use two heaters.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2018 at 3:42pm
How cold does it get in your winters?   If 10F is a cold night you might be able to get by with a window air conditioner/heat pump. You get the advantage of A/C in the summer too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2018 at 4:01pm
MNLonnie I said outside boiler because he mentioned use in a garage, and fear of explosions from flammable vapors (painting and solvent cleaning). It does not take much evaporated solvent or dust in a enclosed area to cause an explosion. If he uses an electric boiler it is not very frugal, where as a outside wood fired or even gas boiler is more frugal to run. Electric hot air is probably the easiest way to go for set up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2018 at 5:09pm
insulate before buying any heat source. I have a natgas furnace in my 2 car garage in a separate but attached room . It's also where the air compressor lives. I use quartz IR heaters to warm up tractors long before painting as warm air will never get cold cast iron up to painting temp 25*C/70*F. I do shut off the furnace when painting,primarily to stop the air from moving.
Reindeer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2018 at 5:42pm
I have a couple of what we call tube heaters.  They burn natural gas inside a 4" steel tube, so the fire is contained and exhausted.  The heat is infrared, so keeps the machinery nice and toasty.
 Very important to insulate well, as that will cost much less than trying to heat an uninsulated space.
There are many manufacturers of the tube heaters.  Attached is a link to a local one in Calgary.
*DougW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote *DougW Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2018 at 7:28pm
I like my tube heater, heats objects, not air. Efficient, safe, basically maintenance free.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2018 at 8:07pm
tubes are GREAT, just be sure you have the height for them ! you need space above as well as below. not all are the same either so do a LOT of looking online before you  buy.
In my garage setup I don't have any ducting. simply 2 holes in the 'utility room' wall. cold air from garage goes into furnace(through 2nd 'rough' filter), hot air comes out other hole up high. Simple 2 vane 'shutter' to get hot air..here and there.
Been that way for 20 years, every winter I look at putting in ducting but then decide having a 20x10 duct down the middle of the 8' ceiling would be a royal PITA !! furnace is 75K BTU, heats garage to 'nice' in 10-15 minutes, 'florida mode' in 30.
Jay
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2018 at 8:42pm
I would not have heaters that heat objects. IH dealer had them. Hot in one place cold in another. I don't care if tractor is warm, I want to be warm.   MACK
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2018 at 1:31am
Have you poured the cement floor yet if not put radiant heat in the floor even if you don't hook it up right now you can't put it in later
Fat albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fat albert Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2018 at 5:52am
I agree with Mack on the infrared tube heaters. As a hvac technician. One end of tube is 800 plus the other is 180f and feels cool also have seen many times where paint has burnt of objects that are too close. Still better than no heat.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2018 at 8:08am
So many variables, so many choices. My old shop had a forced air furnace that I could shut off when when I was not to be in there for a while. I'd go out and start furnace a half hour before I wanted to work in there but floor was never warm. Fuel costs could be low as it only runs when you're in there. Downside is flammable vapors could pose a threat. Remodeled shop 5 years ago. Raised the ceiling and poured a new floor with radiant heat. A small boiler hangs on the wall out of the way. Sealed combustion chamber draws air from outside. Up side is no risk of fire from fumes and the floor is warm which allows a lower thermostat setting. Downside is you cant shut it off during heating season because it takes too long to bring up to temp. The lower t-stat setting and highly efficient boiler make up for that. IMO IR tubes are nice but there are warm spots and cool spots and you gotta watch your head room. All in all I love my warm floor best.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2018 at 8:28am
By inside boiler I meant electric, only way to go. Although I do use water tubes in the floor it could be set up with a heat exchanger of some sort for hot air. I know plenty of people with outside boilers on wood and gas, they are as inefficient as you can get. Most people figure around 15-20 cord of wood or $1500 in gas. My shop is 30x50 and it is kept at 70 degrees all winter for $800. The boiler is 18" square and 4" thick hanging on the wall.
One complaint I have heard on infrared tubes is that if you are on top of a vehicle you will get cooked because you are too close and if you are under it you will freeze because you are not in sight of the tubes so there is no heat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2018 at 8:52am
To clarify, My boiler is a LPG boiler. 30,000 BTU heats 2400 sq ft. with 12 ft ceiling. Cost $750 last season with thermostat at 65 degrees. This cost is based on the price of LP when you call for fill.
I helped a friend of mine install a warm floor in his new building. Same size as mine. He chose an electric boiler. Has separate meter from REC for a different rate. IDK what it cost him to heat last season, I'll find out. Interestingly, he has an outdoor wood boiler for heat and hot water in the house but did not route a loop to the new building. He claims to like cutting wood but it takes a lot of time. Me, I have better things to do than cut wood for heat.
BillinAlberta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillinAlberta Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2018 at 1:05pm
2 connected 30 by 30 by 12 foot high shop spaces.
  1 is heated by tube infrared-50000btu. I keep it at 10c when I'm not working and crank it up when needed.Works great for me. R20 insulation all round helps.Well sealed doors are also important.
  Just finished insulation and closing in the other side so I went looking for a heat source.Seems like the tube heater works well and calls for 50000 btu input while the unit heater needs 80000 btu input for similar performance and around the same cost installed.
   Given my experience with radiant heat the savings in gas input makes it a no brainer.
   I  also worked in a shop with underfloor heat for a while and found it unpleasant working under vehicles. Too freakin' hot! A bloody mess when it sprung a leak to boot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2018 at 1:50pm
Jay commented on the height requirement for tube heaters.  You do need to have a minimum of 4 feet from the heater to any combustible surface according to the instructions for mine.  Ignore this and you may get some surprises.  Heard of one chap who put one too low over his vehicles, and ruined the paint.
As long as you have room and the building is well insulated, they keep things very comfortable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2018 at 2:56pm
I use forced air if you use a newer unit with vented combustion no risk of fire also use a programmable t stat keep all programs set at say 50 deg turn it up when you go out to work if you forget to reset it the next time setting will automatically put it back on 50
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2018 at 4:08pm
I think this question is kind of like asking what a tractor is worth. You will get a lot of different ideas, depending on each person's opinion.
I have a wood burning furnace. While it works for me, I can understand why it might not work for you.
Someone mentioned electric. Electric rates here are very high, which makes it not viable in our area. My son-in-law and daughter live 12 miles away in Quebec. Their "hydro" (electric) rates are very reasonable and they have an electric furnace that heats their house.
I think you have to consider the options that you feel are safe and pick the one that best suits your wants and needs. There is no universal right or wrong answer.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2018 at 4:45pm
I'm on my second shop/garage, and I've had/got L.P. fired tube heaters in both. In shops where you're not  in working every day, it's the best way to heat it. If it's being worked in everyday then maybe the hot water in floor may be better.
My shop that I'm in now is a 30'x40'x10' Morton pole barn, with 2 10'x8' over head doors and one service doors and 3 double pane windows. It's very well insulated. I put in a Dayton 50,000 btu tube heater.
The instructions say that the way that I have it installed that it needs to be 6" below combustibles, 48" above until 20' from burner, then 30"
This type of heat is great, especially if doors are opened often, or even outdoors in an area that protected from the wind. Its like being in the sunshine.
If you're going to install it in a shop that there will be combustibles vapors you should pipe the combustion air from outdoors to the burner fan.
Dusty
Brampton 02 gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2018 at 5:15pm
I heat my insulated 2 car garage with a 220 v (30amp) milk house electric heater. I think it is 4500 watts up here in Canada.   I start it and let it run half hour before I go out and it is warm enough I don't need a jacket. After a couple of hrs it is too hot and I turn it down. Cost about 50 cent an hr to run I figure with our overpriced electricity here in Ontario. Looked at natural gas but pay back was not there.   Only drawback is fan on heater is a bit loud.
This page was generated in 0.052 seconds.
