Air compressor issue
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Topic: Air compressor issue
    Posted: 12 Sep 2018 at 8:21pm
I have a 60 gallon Ingersoll Rand SS-5 compressor that is about 8 years old. Very little use and well maintained. Every thing was great until the last week. It runs as it always did until it reaches around 100psi in the tank and then it falls on its face and the motor bogs down and the belt even starts slipping!! If the breaker doesn't trip after about 10 seconds of this belt squealing it will pick right back up u til it shuts off. Any ideas on this? Thanks in advance, Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2018 at 8:34pm
Have you drained the water from the tank recently ?
Have you replaced the belt and adjusted for proper tension ?  Any slipped belt will become 'glazed', so not as 'grippy' as it's supposed to be so when the motor sees extra load( 100 PSI), it'll 'stall' out. Not the right 'engineering' terms but...hopefully you get the drift..
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2018 at 8:40pm
I relocated the factory drain valve so it is out front and it is drained after every use. The belt seems as tight as it should be. This issue just rapidly started happening and I am needing advice before I call the company. Ryan
Edited by Ryan Renko - 12 Sep 2018 at 8:41pm
farmboy520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2018 at 12:06am
I wonder if the check valve that is after the compressor and before the tank is operating correctly?
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2018 at 3:23am
try adjusting the PSI down a little bit
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2018 at 10:02am
Grandpa has an air compressor from the '50s and it has this problem sometimes.
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2018 at 10:11am
  Well,,I started havin the same issue with my compressor couple weeks ago and I figured it was the motor as it is very old,,,,but since that time it has been runnin just like old times,,,,WHH,,,,???
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2018 at 3:44pm
I agree with the check valve issue, it is getting some back pressure above 100 psi and the pump is trying to push against a closed/part closed valve. Could be a broken or corroded spring that all of a sudden let go, I imagine that would be an fairly cheap part.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2018 at 4:28pm
Aunt Peg would say they are sending  cheap electricity and charging premium price.
