D19 yr 1963 |
T-bone_indy
Silver Level Joined: 06 Sep 2018 Location: Indiana Points: 68 |
Posted: 06 Sep 2018 at 5:19pm |
I just purchased a few days ago.Getting the rim repaired now.
so far I have change the oil and filter hydraulic filter added 4 gallons of hyd fluid greased every fitting i can find Repair hydraulic leaks and fuel leaks Loader is functioning now I have a question when raising the bush hog the arms go down immediately once i release the leaver. is the loader a 500? where can I order pins for it? I would appreciate any points and suggestions on the operation of this tract and thanks in advance also the owner stated it only has hi gear not sure if there's adjustment that can be done to correct that. The previous owner has manuals for the tractor hes trying to locate them. Edited by T-bone_indy - 06 Sep 2018 at 5:28pm |
T-bone_indy
T-bone_indy
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7338 |
That is not a 500 loader.
Pete from IL
Silver Level Joined: 29 Dec 2009 Location: Beecher IL. Points: 311 |
It looks like a Freeman loader to me. You may have to repair the pins you have or make some new ones. Someone on here may know if new pins are available somewhere.
hillmonkey
Orange Level Joined: 03 Apr 2010 Location: oville fl Points: 417 |
I like it, good save.
1852 Moore Farm
Bronze Level Joined: 21 Apr 2016 Location: Missouri Points: 91 |
Nice project.
Travis(NE)
Silver Level Joined: 24 Sep 2009 Location: Seward NE Points: 296 |
There is a check valve inside the valve for the traction booster that will leak internally which causes the lift arms to not stay up. Usually it can be taken apart, cleaned, and work again when reassembled.
