220 questions
dirtschlinger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dirtschlinger Quote  Post ReplyReply Direct Link To This Post Topic: 220 questions
    Posted: 30 Aug 2018 at 9:17am
Where can I get a key for a 220?  I assume they are all the same and maybe a key from a different tractor may even work.  It's my grandpas tractor and we can't find the key anywhere.  There is a bracket that runs from one battery box to the other just behind the shifter. This is where my batteries are grounded.  Is this correct?  Is this a good enough ground?  Thanks.
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 10:05am
A lawn tractor key will fit unless the switch was changed with something different,INDAK is the company that made them. Should be able to find one pretty easy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 1:12pm
that original key has been in tractors and lawn mowers forever,all alike and yes thats where the ground cables were attached.You can run them any place that works if you desire.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 3:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 5:15pm
A small screwdriver works also
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 9:32pm
If that is the stile key you need, I'll send you one.       MACK
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 8:31am
217 more questions to go?
Have spacesuit, will travel
Post Options Post Options   Thanks (0) Thanks(0)   Quote dirtschlinger Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 11:00am
Thanks for the responses.  I do need an INDAK key.  I will find one.  Thanks Mack.  Careful what you wish for CreekBig smile
