7030 Injection pump. |
ACFarmer ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Ohio Points: 743 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Jul 2018 at 1:47pm |
Looking for somebody that has put an inline pump on a 7000 series. Have a 7030 with a bad pump, and an A pump laying on the shelf. Seeing what the best combination of parts to use is. I know Ill have to bend lines. I've put inline pumps on older 426 blocks for pulling but wanted to double check if there was anything else out there now days to make it easier. Tractor will only see light duty work and some farm stock pulling now, have a 3LM laying here for a turbo as well.
Making A living everyday farming with and working on Allis Equipment
Alvin M ![]() Orange Level ![]() Joined: 24 Jun 2018 Location: PA Points: 786 |
Call Paul A Countryside Tractor in PA He Put Some In 426 Engine For pulling 717-923-0421
Peterson ![]() Orange Level ![]() ![]() Joined: 05 Mar 2011 Location: Westboro, Wi Points: 862 |
I've done it a couple times, I use the borg warner s300 for turbos.
You'll want to either drill the main saddles for oil squirters or put a set of big pin rods in it for oil cooled pistons.
Fair valley performance is where I got my drive hub for the pump. Machine shop to bore the pump hole and weld the old roosa pump mounting holes shut. Got a Deere pump on our 220, they don't like the retarding plungers though in the Deere pumps. On the 8050, got a deutz pump off a r50-r52. Works awesome! Starts on the first rotation. Pump is set to start of injection and timing set at 31*s.
Edited by peterson - 16 Jul 2018 at 9:20pm |
Thanks for the info. I'll do some more research. Nothing that needs done right away, just getting ideas for a winter project.
