Tough as WD?
1951WDNWWI View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1951WDNWWI Quote  Post ReplyReply Direct Link To This Post Topic: Tough as WD?
    Posted: 12 Jul 2018 at 9:11pm
Any newer tractor as tough as the WD?  Something you can 'slip' the clutch on without fear of burning it up when you get into tough brush hogging.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2018 at 10:32am
define "newer"
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2018 at 10:55am
Hydrastat tractors can be run in an infinite number of speeds, many tractors have way more gears with creeper gears where the tractors can be slowed to a crawl.And lastly there are tractors with much more HP so they can go right on thru the rough stuff
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2018 at 11:14am
You can slip the clutch on a newer tractor with a wet clutch until the cows come home. Is the tractor as tough as a WD? Probably. Will maintenance costs be higher? Yes, considerably. Will the initial purchase price be higher? Definitely. Can you justify a $30,000 tractor only for brush hogging? No.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2018 at 2:24pm
The way things are going, $30,000 for brush hogging will be considered cheap!
deadeye View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote deadeye Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2018 at 3:57pm
You will be hard pressed to find a new tractor that will work for you for 60+ years that the WD has done.  You can slip your hand clutch on the WD all day as long as you have oil in it.  They are one tough unit, can't be beat for the cost.
ACD14Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACD14Man Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2018 at 5:30pm
We run a WD here on the farm for 50+ years. I keep up with the maintenance and repairs and it still does the job.  Every once in a while I get the itch for a newer tractor. After looking at the prices and condition, the old WD looks pretty good. I suggest you go looking for another tractor, you just may find the "old WD" looks pretty good.
