Suitcase Weights
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Topic: Suitcase Weights
    Posted: 07 Jul 2018 at 6:54pm
What do these fit? Sorry for the link I can't figure out how to post the picture. I am looking for weights for my 200 and found these locally. I didn't know if they would fit on the weight bar of my 200.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 7:08pm
maybe 180-190-200 if you got or get the right weight rack they hang on would work ?
JP (nwOH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JP (nwOH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 8:05pm
Those are the 7000 series
Will not fit the 200 weight bracket
d21_man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d21_man Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 8:18pm
Those look like 6000 and 7000 series weights. There was 2 styles of weights used on the front of the 200. The larger ones are almost flat on the top and are used in the 210 tractors as well...hard to find. They have a weight bar with slots and use outside locks on each end like the 6000 and 7000. The other style are smaller and look like the weights used on the 185 tractors. They have a weight bar that has a notch in the middle and a bar that slides through to keep them in place.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 9:01pm
Thanks for the replies yes my 200 has the bracket with the notch in the middle and I was afraid these weights would not work typical for my luck because they are close to me and the seller wanted $75 a piece and has 10 of them.
Tim (Cent.WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim (Cent.WI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 9:47pm
Those are definitely 6000-7000 weights, I have some 200 weights and they are similar but different. Flatter on top like someone said
TerraTiger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TerraTiger Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 9:53pm
Not mine. Saw these from a local search.
Maybe these are the flatter ones mentioned?
https://fortwayne.craigslist.org/grd/d/suit-case-weights/6631521936.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 11:12pm
Nope. Still the same style but only 62 lbs instead of 90 lbs. For 6000 or 7000 series.
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 2:56am
These two stacks are different the first one is 6000 the bottom we're 7000 the difference is the bottom ones fit a curved Bottom bracket bracket they will not fit 6000
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2018 at 8:48am
I believe this is the suitcase style weights you're looking for.  These would be original for the Model 200.  No, they're not for sale.
View of part #:
Post Options Post Options   Thanks (0) Thanks(0)   Quote JP (nwOH) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2018 at 3:38pm
I have ones like Brian F(IL) posted that I would sell.   In northwest corner of Ohio though.
This page was generated in 0.211 seconds.
