Roto-baler operating |
560Dennis
Bronze Level Joined: 30 Apr 2011 Location: NE OHIO Points: 116 |
Posted: 30 Jun 2018 at 9:51pm |
Does the roto baler have to stop every time to unload a bale?
Been awhile since I've seen one run . |
Dan Hauter
Orange Level Joined: 06 Feb 2011 Location: Carlinville, IL Points: 1228 |
Yes. That's why the hand clutch was so important back in the day. Had to keep the PTO running when the operator stopped to unload the bale. I remember an arm at the top front swinging from one point to another that signaled the operator to stop and unload the bale. Never was around one of the Roto Balers with its own motor.
560Dennis
That would be tiring for me with out independent Pto and foot clutch then.
Krazy Karl
Silver Level Joined: 12 Sep 2011 Location: SE MN Points: 203 |
The conveyor should stop then the twine arm about same time should drop and tie bale.
WD45
Orange Level Joined: 20 Sep 2009 Location: STAYNER,ONTARIO Points: 952 |
Dad purchased a new Allis roto baler on June 29/50 and operated the baler with a WF.
when the arm dropped push foot clutch in , put tractor in neutral tie bale , then put tractor in second gear go until arm drops again - was still better than forking loose hay onto the wagon by hand.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Lars(wi)
Orange Level Access Joined: 14 Sep 2009 Location: Permian Basin Points: 7197 |
If I'm not mistaken, was there a model Rotor-Baler that had a feature that allowed non stop operation? Kinda like a extra tray that would continue to gather the hay while it was tripping and ejecting the bale?
grinder220
Orange Level Joined: 11 Jan 2012 Location: Clinton Iowa Points: 2342 |
D17Milo
Bronze Level Joined: 11 Dec 2017 Location: Milo,Iowa Points: 65 |
I remember when I was a kid we had a neighbor with a 2 cly. John Deere, he talked about pulling the clutch back , putting it in neutral, clutch forward, bale out, clutch back and back into gear and the repeat the process.
560Dennis
I don't know that much about theses balers ,but I remember seeing the bales left in the Fields here..
Question is why did they need string knotters ? The twine would rot wouldn't it ,or mice would eat it .. |
MACK
They didn't have string knotters, just wrapped string multiple times around both ends. MACK
FloydKS
Orange Level Joined: 12 Sep 2009 Location: S E Kansas Points: 8118 |
In our picking up bales... we were the knotter...had to take the loose end ( the baler 'knotted' the first end) and slip it under the twine at least once and yank it to knot the final end of twine... took a couple of seconds but saved many a bale from "unwinding" when being handled.
Gary Burnett
Orange Level Access Joined: 11 Sep 2009 Location: Virginia Points: 2939 |
[QUOTE=FloydKS]In our picking up bales... we were the knotter...had to take the loose end ( the baler 'knotted' the first end) and slip it under the twine at least once and yank it to knot the final end of twine... took a couple of seconds but saved many a bale from "unwinding" when being handled.
[/QUOTE They will only unwind one way think its the side that the twine starts on first to your left put it on your right and they won't unwind no need to tie.Think I got the sides right been a long time but I've handled thousands of them.
Leon B MO
Orange Level Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2110 |
They actually had a tool to push the end of the last wrap of twine down into the bale. Looks like bale hook on one end and a needle on the other end. Even had a special storage spot on the baler. I don't have the baler any more but do have the tool.
Leon B Mo
