WD carb issues?
russt66 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote russt66 Quote  Post ReplyReply Direct Link To This Post Topic: WD carb issues?
    Posted: 02 Jul 2018 at 7:46am
So the tractor will start and run fine. After a lap Or so so pulling a plow. It stalls and dies. If I fiddle with the choke, about half pull, I can limp it back to the house. Choking, sputtering, dieseling, if I don't hit the sweet spot with the choke. Let er sit and cool. Then it runs fine again until I pull the plow again. Occasionally with the tractor just sitting and off, fuel will drip from the carb air intake hose area. I just use the fuel shutoff valve when I turn it off. Is this a common problem? Sticking float maybe?
Edited by russt66 - 02 Jul 2018 at 7:47am
baverwolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2018 at 8:30am
Fuel cap not venting??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2018 at 9:31am
That could be a number of things. Dirt and debris in the tank playing havoc with the needle n' seat, sinking floats, plugged vent (depending on mfr of carb) and the list goes on. I would say, start at the tank and start cleaning the fuel delivery system up. Then rebuild or have the carb rebult. Make sure the fuel system is nice n' clean before installing the rebuilt carb. You'll have the same problems again..  HTH  BTW, we offer Carb rebuilding if interested....
Steve@B&B
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2018 at 9:40am
I had the same problem. I'd clean the tank, rebuild carb, over and over, but wouldn't resolve the issue. I finally replaced carb with one I bought from a fellow on the forum, AND put an automotive fuel filter in line between tank and carb. problem solved!
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote russt66 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2018 at 1:56pm
Thanks, I will report back after the carb rebuild is installed
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2018 at 2:49pm
I think the reason I had to keep rebuilding carbs was because of fine rust from the tank. I think the filter helped as much as anything, that little screen in the settlement jar just wasn't cutting it
Wait for the Lord;
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2018 at 12:06pm
Also, do a half-inch Stand-Pipe inside the tank to keep the rust from getting into the fuel system.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2018 at 12:58pm
All of my wd and 45's do the same thing.--tank cleaning and auto filter don't help either.
Some say the tanks will need to be coated inside to stop the problem.
My 45 dumped me the other day on the road pulling the tri-axle loaded with the big water tank.---Had to walk home and carry a air tank with blow gun and blow rust out of the load jet, then we came on home purrin like a kitten! LOL!! thanks; ac fleet
Edited by ac fleet - 05 Jul 2018 at 1:04pm
