Water Hemp in Soybeans
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Topic: Water Hemp in Soybeans
    Posted: 18 Jun 2018 at 2:45pm
Anyone else have this weed ?
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2018 at 3:09pm
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2018 at 9:19pm
Marestail is a real pain.  It drinks spray.  Hit the marestail with a disk, in two different directions.  Went two different directions with sweeps, still not eliminated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2018 at 10:17am
Amaranthus tuberculatus - Wikipedia
https://en.wikipedia.org/wiki/Amaranthus_tuberculatus
Amaranthus tuberculatus, commonly known as roughfruit amaranth, rough-fruited water-hemp, or tallwaterhemp, is a species of flowering plant. It is a summer ...
10 timely tips to simplify waterhemp control in soybeans | Indiana ...
www.indianaprairiefarmer.com/.../10-timely-tips-simplify-waterhemp-control-soybea...
Jan 28, 2017 - There are three types of farms — those that have waterhemp, those that will have it and those that already have it but just don't know it yet, says ...
8 facts you should know about waterhemp | Indiana Prairie Farmer
www.indianaprairiefarmer.com/.../8-facts-you-should-know-about-waterhemp-indian...
Jan 16, 2017 - If you haven't seen waterhemp on your farm yet, Bill Johnson says you likely will. And while waterhemp is in the pigweed family, it can prove
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2018 at 12:23pm
I was no-til for 10+ years. My local chemical coop service liked to over indulge with Glyphoate treatments. Waterhemp seed over winters in residue & probably built up tolerance to herbicide? Anyway I bit the bullet & did a deep moldboard plow during a very dry February, turning under & burying much of old waterhemp seed. Then, followed up next year soybean crop using Liberty Link variety. I also changed to a better local chemical coop service applicator who understands weed challenges. He applied Liberty, Union, & Triple Sec post herbicides which cleaned up field last year. I purposely planted later June 5th, so I could allow early flushes of weeds to be field cultivated out. Seems to be helping.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2018 at 4:44pm
I used to get a lot of pig weed in my beans if it was a real wet year.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2018 at 11:12am
That must have been after you stopped using a Gleaner.LOLLOLLOL
WinkUs to be spots where I helped cut safflower with a Gleaner that had lots of pig weed,it all came in with safflower. The boss man figured out being smaller seed than safflower if he ran it across hardware cloth it would fall out and safflower would run down hill into the semi. Parked his bobtail under the screen and catch the pig weed and haul it off from the fields. So not much seeds for next year.Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2018 at 12:23am
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2018 at 3:56pm
Next year get Liberty beans and watch them weeds DIE!
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2018 at 9:19am
dicamba really smoked the pigweeds for me this year
Jwmac7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jwmac7060 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2018 at 12:33pm
Plownin the fall and Liberty is the only way to treat it...if no tilling put sharpen on it at burn down..but working it is best
This page was generated in 0.104 seconds.
