trailer ramp springs
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Topic: trailer ramp springs
    Posted: 14 Jun 2018 at 6:32am
I am thinking about putting ramp assist springs on my trailer. I have bobcat ramps and need a gorilla to lift them up. I have found some but they install on the rail which I don't have. Looking for suggestions. I should have had them put on when they built the trailer as my wife reminds me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2018 at 9:39am
Some use a coil spring that counterbalance ramps - shaft or pin that ramps hinge on go through the center of coil spring with spring tension counterbalanceing the ramp .
CaseyCreek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CaseyCreek Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2018 at 10:29am
Is this what you mean?
(Gorilla-lift assisted trailer lift)
D17 Series III,D17 Series IV, 185
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2018 at 11:51am
I guess I did not know there was one by that brand name. But I don't have rails. Coke I have seen the coil spring type and was wondering if they work?
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2018 at 12:02pm
My dad had the same problem with the ramps on his lowboy when he loaded his dozer, he had a chain fashoned to the ramps and at first he would load the dozer on the lowboy just past the ramps, get off, hook the chain to the back of the dozer, pull the dozer forward and let it pull the ramps up.  Later on he made a hook that he could drop as he was loading that would catch the chain and he didn't have to get off until it was loaded and the ramps were up.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2018 at 2:52pm
mdm1, here's a couple utube video's i'm looking at for what you seek.
Hope this helps
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2018 at 4:40pm
The second one could maybe work. Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2018 at 5:01pm
Google trailer ramp torsion springs, about $20, IIRRWink
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2018 at 6:58pm
The torsion springs are what I have considered and would be by far the easiest to install.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2018 at 8:20am
I ordered the springs. Thanks for the suggestions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2018 at 10:11am
please be sure to OIL the torsion springs with a 'thick' oil or rust check OFTEN, both when 'open' and when 'closed'. it ain't fun when one of them breaks..
This page was generated in 0.191 seconds.
