M70 Motor Grader
Staci View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Staci Quote  Post ReplyReply Direct Link To This Post Topic: M70 Motor Grader
    Posted: 12 Jun 2018 at 3:04pm
Hi,
Does anyone know where I can find information on a M70 motor grader?  I have the model and serial number. Model a-1 9800 serial number 33553.
Any help would be appreciated!
Thanks
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2018 at 3:20pm
M70 was the replacement for the 145T.  produced from 1963-66  but only 250 units.  it used the 7000 engine.  344 cu inch turboed for 115 hp.  the control system was common with the M100 and it weighed 23,100 lbs.
my book shows serial #s  listed as 1-250 not sure what those numbers you posted are from.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Staci Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2018 at 3:38pm
I got it off the plate that is on the machine there is another plate that says M70-166
Post Options Post Options   Thanks (0) Thanks(0)   Quote Staci Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2018 at 3:39pm
I tried to post pictures but my phone won’t cooperate
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2018 at 3:42pm
166 would make it a 1964
you have to upload your photo somewhere in order to post it here.
Edited by CAL(KS) - 12 Jun 2018 at 3:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Staci Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2018 at 7:11pm
Thank you for the information, very helpful, very much appreciated, do you know about what it’s value would be? We are planning on re conditioning it
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2018 at 7:27pm
A SWAG*  here
The AC45 (10000 engine) parts book I have has a note that it was used with a 145T - obviously didn't work for the engine
So is it possible that the M70 could similarly use the books for an M100?
*  SWAG = scientific wild arsed guess
This page was generated in 0.593 seconds.
