7060 pto
allisfarmer2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisfarmer2 Quote  Post ReplyReply Direct Link To This Post Topic: 7060 pto
    Posted: 18 Aug 2010 at 8:37am
Pto will not shut off unless you shut off the engine, is this major or can I fix it myself with the help of an IT book ?  THX   allisfarmer2
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2010 at 8:55am
pto cable just needs adjusting,easy to do,its on the right hand side of the tractor back end.But the adjustment is a fine line,wont disengage one way or it wont stay engaged if adjusted a tad the other way.You can get the pto to disengage by also pushing on the brake pedal at the same time or pumping one of the hyd remotes at the same time as you push on the pto lever.Hope this helps.
