Removing a pillow block bearing |
littlemarv ![]() Orange Level ![]() Joined: 10 Jun 2013 Location: Wisconsin Points: 1829 |
![]() ![]() ![]() ![]() ![]() Posted: 30 May 2018 at 9:36pm |
As in, how do you?
I need to remove this bearing, and reinstall it on a shaft. I am shortening the shaft, so I was able to just cut it off. I removed the collar with the two setscrews, and tried to air hammer the sleeve off the shaft. If nothing else, I can find a piece of pipe and press it off in a hydraulic press. Or am I going at it all wrong? Thanks in advance. |
The mechanic always wins.
B91131, WC23065, WD89101, CA29479, B1, Early B10, HB212, 416H |
Coke-in-MN ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Afton MN Points: 41312 |
Soak it good with penatrant and then using a press - it should come off - or not !
Snowvalley Dairy ![]() Orange Level ![]() Joined: 26 Aug 2012 Location: Bangor New York Points: 295 |
make sure to polish the shaft with emory cloth or sandpaper. also remove any burrs with a file or grinder then press it off.
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50833 |
Tried the wax trick, yet?
klinemar ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Michigan Points: 7938 |
All of the suggestions are good. The wax trick works much like penetrating oil as long as it penetrates. I have had bearings like these that had been run in haylage that actually welded themselves to the shaft and had to be cut off with the torch because I did not have a press ! Sometimes all you saved was the shaft !
Most likely set screws have made a burr on shaft and you will have to force it over burrs to get off . Penetrating oil may not help much.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21738 |
my 'cheat' is to take a 4 1/2" angle grinder with a THIN disk on it. Mount pillow block i vice ,clamping the base of the block.Make 2 vertical cuts to ALMOST the shaft. Whack off the 'cut' portion of the block. NOW the shaft may slide out, if not CAREFULLY cut/grind to really close to the shaft. Use hammer to bang out shaft from block. 'dress' the shaft to 'as new' condition. Takes me maybe 1/2hr of reasonably pleasent time to do it this way and no cuts or other booboos on my body. Jay
Good thread, thanks for the help. I am trying to save the bearing, not the shaft. I'd imagine the bearing is not cheap.
At any rate, soaked it in penetrating oil for a few hours, then found a piece of pipe that just fit over the shaft. The press never even grunted, she just slid right off. Thanks again. |
Clay ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Udall, Kansas Points: 8994 |
Everyone has made excellent suggestions.
Clean rust off shaft with abrasive paper. File off high spots. If the end of the shaft has be hit and mushroomed, use of a Dremel or grinder may be necessary. Soak with KROIL. Give it time to work. Go have lunch or come back tomorrow. Use a suitable puller or press. It may be necessary to hit the old bearing. Use a phenolic block or brass drift. Sometimes a punch in an air hammer will do the trick. |
LouSWPA ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Clinton, Pa Points: 24091 |
Dynomite!
I am still confident of this;
Reminds me of guy I worked with as a mechanic in station (way back)
Had a special press for wheel bearings on axle shafts - customers came in and bought a bearing from him and asked to have it pressed on axle as he could not get old bearing off - took into back room - big hammer broke outer bearing race - dull chisel into bearing groove of inner race to remove that - slide new bearing onto shaft - 3' long pipe used as a driver and pound bearing home -
Charge customer for use of special wheel bearing press and special puller and bearing . |
Michael V (NM) ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: NM Points: 2365 |
What you really need to save is the pillow block...the bearings are relatively cheap to replace...if ya hafta replace the complete unit, that gets $$$$$
