Woods L306 belt
woodsman89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote woodsman89 Quote  Post ReplyReply Direct Link To This Post Topic: Woods L306 belt
    Posted: 26 May 2018 at 7:40am
putting a new belt on mower, C tractor. The belt going forward from the left idler seems to have more twists in it than it should. 1/4 twist coming back from right side of mower, 1/2 twist coming down to left idler. New belt from dealer, WOW, don't want to wreck it.
Is that what getting old is? Simple things become complicated?
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2018 at 7:51am
Lots of twists in the belt. You can download the manual (has pics of belt routing) from the Woods website. PM me ypur regular email address if you can't locate it and I will email you a copy
Edited by GregLawlerMinn - 26 May 2018 at 8:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 8:35pm
I think that the twists that you talk about are correct.  It's not real difficult, but it sure helps to have the diagram and a picture of it.  Good luck with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2018 at 6:42pm
It’s frustrating to adjust but when you get it correct it works very well. Quite a few twist. Can get you a picture next time the CA is outside, that is when it finally stops raining. Calling for it the next 10 days here.
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2018 at 8:08am
So who makes the best belt for these mowers? In searching old posts on here, I've seen "JD dealers usually have them in stock" , "only use woods belts", "my woods dealer recommended brand X",  etc.
Lord knows what you are getting when you google it and order it from Amazon or something.
The mechanic always wins.
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2018 at 8:50am
I use Napa B255 on my Ca w/L306--a little longer, works better and cheaper. It allows you to move the deck forward a few holes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2018 at 11:55am
Is there an advantage to having the deck forward?
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2018 at 3:32pm
Clearance for belt assembly, and slightly longer for the twisted length should help reduce heat in the belt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2018 at 3:18pm
Well, I snapped some pictures for my own future reference, but I thought maybe others could benefit from them as well.
The belt makes a 1/2 turn from the left idler up to the drive pulley,
3/4 twist from the top groove of the center spindle to the left idler,
and a 1/4 turn from the right idler to the bottom groove of the center spindle.
Hope this helps.
This page was generated in 0.065 seconds.
