Used antifreeze |
Ryan Renko ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edwardsville, I Points: 2335 |
![]() ![]() ![]() ![]() ![]() Posted: 23 May 2018 at 5:37pm |
I always find a proper place for my used motor oil but what do you all do to properly dispose of used antifreeze?? Ryan
When I was working we kept it in a drum and the haz mat co. picked it up. At the time green antifreeze was not considered a haz material and could be disposed of any way you wanted to.
dawntreader74 ![]() Orange Level ![]() ![]() Joined: 28 Oct 2013 Location: Manteno Points: 1770 |
you can take it to a oil change place' will take it or may even pay a little for it'
CrestonM ![]() Orange Level ![]() ![]() Joined: 08 Sep 2014 Location: Oklahoma Points: 8455 |
I've always wondered that, too. I have a 5 gallon bucket of the used green stuff, but never knew where to take it.
you guy's ever test that green stuff. you mite be throwing out better then what your getting ? i got 55 gallons from a auto yard a few years ago for not much cost an it tested dam;;good. an also clean.
The critters around my place like its taste.............that's not wrong is it?
![]() I must admit that mine goes on the ground as I didn't know what to do with it.
1957 WD45 dad's first AC
Put it in the back tires on your Allis tractors.
Ray54 ![]() Orange Level Access ![]() Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4723 |
Who ever has any around,seems to always goes away one drip at a time. Or the hose blows
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12150 |
CaseyCreek ![]() Silver Level ![]() Joined: 03 Apr 2011 Location: L.A. Points: 332 |
CTucker, you are a genius!! I take mine to a local recycling center. I had to call several because most places will take oil but not coolant. I was lucky enough to find one that did. Edited by CaseyCreek - 24 May 2018 at 1:52pm |
D17 Series III,D17 Series IV, 185
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24646 |
I put mine in whatever plastic containers I got, mixed with oil, tranny fluid,gas,water and take to recycle center, The kid always ask was is it, I say old oil, offload then go. It ain't MY problem......they get paid big $$ for the oils and paints and such, so I don't feel bad. I do feel bad when it goes on the ground here though.
jay |
VFDfireman ![]() Silver Level ![]() ![]() Joined: 11 Jan 2013 Location: South Dakota Points: 414 |
Start with your local auto shop. Also try your local land fill...most likely they have a program for collection.
Please don’t dispose on the ground...used AF is loaded with heavy metals that can leech into the ground water and usually has fairly low pH depending on the age of it. |
1954 WD45 Restored 2015
Current Project: 1953 IH R120 Pickup truck CB "It's better to be thought a fool than to open your mouth and remove all doubt." |
Kurt WI ![]() Orange Level Access ![]() Joined: 19 Oct 2011 Location: Cascade WI Points: 3242 |
Geez you guys have that problem??? I always seem to need more new after a water pump goes ora hose blows out!
WD D17D 170 190xt 190xtIII 200 7020
I take it to work we've got an antifreeze recycler there.
Edited by Dakota Dave - 25 May 2018 at 4:30pm |
it will kill your pets and other animals if drank. it's a slow painful death
ACFarmer ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Ohio Points: 746 |
Wish you guys were closer to me, I'd take it off your hands. We use it in the bottom of our dump trailers in the winter to keep product from freezing in.
Making a living farming with and working on Allis Equipment
ACFarmer, what "product"?
Scrap, coke, whatever may be wet and freeze to the bottom of the trailer.
Coke-in-MN ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Afton MN Points: 41979 |
guy I woked for this spring treats his dump boxes with it has a sprayer in the cab and each morning on the job spray a lite coating on box floor or onto box liner - keeps the dirt from freezing to box - as we were hauling trenching material from old sewer lines in city much of it was wet and without treating box you would have dirt frozen to metal
just don't use that recycled antifreeze. they don't put nuff of the right stuff back in it.
BrianC ![]() Orange Level Access ![]() Joined: 16 Jun 2011 Location: New York Points: 1619 |
Many car dealers will take your coolant.
Dennis J OPKs ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Overland Park, Points: 517 |
This wouldn't work for 99% of you because it can't be done with a septic tank. Here in area served by Johnson County, Ks. Wastewater it is acceptable to put anti-freeze down your drain and it causes no problem in going through the sewage treatment plant. Go figure.
