My new WD45
chief915 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chief915 Quote  Post ReplyReply Direct Link To This Post Topic: My new WD45
    Posted: 23 May 2018 at 1:10pm
Hello everyone. I just got home with my first WD45...... It's been sitting for 18 months.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2018 at 1:13pm
Welcome!!  She looks complete except for the fenders.  If you have any questions you have come to the right place.Thumbs Up
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2018 at 1:21pm
And the fun begins! Welcome.
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2018 at 2:16pm
Needs more orange.  Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2018 at 2:22pm
Welcome to the Forum! That is a neat find. Spray some orange paint on it and it will look much better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2018 at 4:31pm
Congratulations! Welcome to the forum! Good 45 you have there. What are your plans?
Post Options Post Options   Thanks (0) Thanks(0)   Quote chief915 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2018 at 6:11pm
Thanks guys..... not my first old tractor, but it is my first bigger AC, I did have a 720 and still have a 712S. Even though I'm a fairly young guy, I love old iron.
Right now I'm working through checking it over to see what's broken, not working right, missing, etc on it. I got it running in less than an hour after dragging it home. The tank had water and other nasty in it..... flushed that out, put in some fresh gas and a hot battery.... I bet it didn't turn over 3 times until it was running.
It does have a slight pop/miss/puff sound from the exhaust while it's running. All 4 plugs look fine, are gapped correctly, and are similar in color. The plug wires are all connected good at the cap and plugs, and are in the correct firing order. The points look good and are gapped at .020. The valves are all set correctly and the tractor has 130 psi compression on each cylinder. The previous owner was told that it was rebuilt not long before he bought it 10 years ago. I took the carb apart and it was fairly clean inside to start with.... I cleaned it and put it back together, and adjusted it with no change in the miss/puff situation.
As far as the way it looks...... I'll eventually paint it....but they have an "ugliest tractor" trophy at the local show coming up this summer..... I think I'm solidly in the running for that award LOL.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chief915 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2018 at 6:21pm
Here's a quick video of it running..... not sure if you can hear what it's doing or not lol.
[TUBE]r_JA4PdvhjA[/TUBE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote chief915 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2018 at 6:34pm
I feel like you can hear the sputter or random change in sound better in this video.
[TUBE]YqtSzhp_T1Y[/TUBE]
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2018 at 7:15pm
I've had a couple 45's they are a good tractor in that size range.   If it were me I would find a light to moderate load and just use it for a while, it may come out of it.  Looks like a recent new manifold.
RJBoll View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RJBoll Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2018 at 8:19pm
Good Find. When I started my rebuilt WD engine it had a slight miss at slow speed. I moved the timing just a tiny bit and it smoothed right out. My D-17 would miss once in a while at idle. I put a hotter coil on it and that fixed the problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2018 at 8:36pm
A little bit of TLC will make a big difference!  You have a good start already!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2018 at 9:07pm
Looks a lot like my 45 project! I need to get a comprerssion tester! Good job checking it over and getting it running. Doesn't sound to bad to me.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2018 at 6:54am
Sounds like you made a good find. It's great when you can find a tractor that solid mechanically from the start
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2018 at 7:19am
The link rod from the governor arm to the carburetor is on bass-ackwards.  This can make the governor linkage stick and bind.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 8:55pm
I didn't think I would EVER SAY this about a WD45, but that is one UGLY tractor!  I think you could be a winner in that contest.....
You can bring her back in a hurry right after the contest, an number 1 is getting her back to Orange....PLEASE,,,,,LOL.
You know, you could easily lose that trophy when some one comes with a NEW John Deere....THEY ARE UGLY brand new!!
