A/C advice |
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6621 |
Topic: A/C advicePosted: 14 May 2018 at 7:52pm |
Got home from the farm Saturday and turned on the upstairs air conditioner and in a few hours the evaporator coil was a solid sheet of ice so I had to shut it down. And the last few days have set a heat record for this time of year. I have used up all of my R22 and don't want to spend the $$$ to buy a new drum of it so I have got in a call to the heat and air company. This is a 20+ year old heat pump and I have had to recharge it about every other year so I am thinking about biting the bullet and getting a new unit. I can get a $400 rebate from the electric company for a high efficiency unit. Think I should try to get a few more years out of this one or replace it? Thanks in advance.
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35695 |
Posted: 14 May 2018 at 7:59pm |
If you have the area for it go ground source, you will NOT egret it.
Our home is 1800sf main level, about 2/3 that finished lower, heat and cool it with a 7 ton GS Heat Pump. No wells just three five hundred foot laterals 6' under grade. |
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25548 |
Posted: 14 May 2018 at 8:18pm |
Herb, your evaporator probably is leaking. time to replace my friend
I am still confident of this;
LouSWPA
Hubert (Ga)engine7
Posted: 14 May 2018 at 8:52pm |
I am thinking it is a very small leak in the evaporator.
shameless dude
Posted: 14 May 2018 at 9:07pm |
gits down there and sniff around it!
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Posted: 14 May 2018 at 9:36pm |
Yep, Lou got it, get a new one. They have a sealer, but that usually does more damage than the cure.
