OT Multifax Grease
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Topic: OT Multifax Grease
    Posted: 04 May 2018 at 3:10pm
I've acquired a 1974 Doyle lime/fertilizer spreader that I'm currently servicing lubricants in it's transmission cases, side case, & spreader (two spinners) cases. The Trans & side cases take 90w lube, but manual says to use multifax grease in the spreader cases. I've searched online for multifax grease & not found anything. Anyone know a modern reference for multifax grease? Thanks
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 3:38pm
I come up with a lot of MULTIFAK EP GREASE as I am sure you do. Could this be your modern reference or maybe there was a spell check error? Just thinking.
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2018 at 6:33am
Our coop just bought 8 Doyle spreaders,have you contacted them?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2018 at 6:37am
Yes. After I posted here, I looked up Doyle mfg number & called them. Man at Doyle told me to use cornhead grease.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2018 at 7:41am
That's good. Just getting cought up on older post.
This page was generated in 0.112 seconds.
