How to jack up a B front end? |
1939Dodge
Orange Level Joined: 18 Jan 2014 Location: Pa. Points: 554 |
Posted: 27 Feb 2018 at 3:58pm |
I have to replace front tires. What methods are being used to crib up and Jack the front ends off the ground?
Gary
Orange Level Access Joined: 13 Sep 2009 Location: Peterborough,On Points: 5204 |
Deja - Vu !! |
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78560 |
I jack in the center and put a small wood wedge above the axle on each side so it wont pivot...... but in reality, if you jack in the center and the back tires are on the groung, you have 3 point stand, so the front tires can wiggle without problems.
1939Dodge
Thanks Steve. I have a small floor jack, I guess I'll crib up as high as needed, set the jack under the wishbone, as hope for the best.
Dakota Dave
Orange Level Joined: 12 Sep 2009 Location: ND Points: 3907 |
I've used a piece of 2x4 under the bottom of the oil pan drill a hole through it and put over the oil plug and a bottle jack. When you take one off the other drops to the ground but you can easily pick it up with one hand.
Gary Burnett
Orange Level Access Joined: 11 Sep 2009 Location: Virginia Points: 2873 |
Put a front end loader bucket over the front of the tractor and hook a chain to each side of the axle and lift it right up
zulawski87
Silver Level Joined: 28 Apr 2014 Location: Foley, MN Points: 85 |
Why not drive one tire on a 2x4. Change one side out and vise versa. You can only do one tire at a time anyway
Michael V (NM)
Orange Level Access Joined: 12 Sep 2009 Location: NM Points: 2355 |
B has a wide front so that wont work...
drobCA
Orange Level Joined: 20 Jun 2017 Location: Perris, CA Points: 292 |
I guess I'm old school - I prefer to jack up one side at a time.
I had to do a multiple tire switcheroo recently, and the tractors are on dirt. so I cut 4x4's 6" longer than my small floor jack; cut plywood the same length and a few inches wider than the jack and nailed the plywood to the 4x4's. made 3 like that and 1 "double". so I can quickly stack them up, slip in the jack and go.
3 Ford 8N's I loan to neighbors, but the '52CA, '41B and little B1 I do not.
DaveKamp
Orange Level Access Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5652 |
Block the tractor's rears, Pull your forklift up to it, set the handbrake, and pull the lever back. When the tires are about waist-high or so, shut off the engine... back off the lug bolts with a rattle-gun, place wheels and tires in pickup... have tire shop change tires... return, replace, and reverse...
1939Dodge
I don't have a crane, forklift, front end loader , sky hooks or helium balloons. Just a floor jack. And it's a 1939, so the rims are removed by taking the bearings out.
So I'll crib up and Jack the wishbone, and hope for the best! |
Gary Burnett
Probably put a jack under the torque tube will lift the whole front
R.W
Orange Level Joined: 31 Dec 2010 Location: Swanton, OH Points: 2975 |
