one tough bolt |
Danny NM
Joined: 28 Dec 2009 Location: New Mexico Points: 69 |
Topic: one tough boltPosted: 07 Aug 2010 at 8:05pm |
Hello everyone been trying to break free a support bolt on the radiator and guard assembly of a HD6. It has a flared head and is about 1.5 inche dia. NFT. The nut is square about 2 inches deep with a step for a retaining bracket. not having much luck. Was wondering if anyone might have a spare bolt & nut that they might part with? Thanks Danny
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35771 |
Posted: 08 Aug 2010 at 12:43pm |
Are you sure it is a bolt and not a pin? Some pins are only equipped with a drive type for alignment purposes as they are splined or keyed to prevent installed rotation. Could it be possible to remove the nut and drive it out?
HD6GTOM
Posted: 08 Aug 2010 at 1:29pm |
It is a bolt, I will look and see if I can find 1 laying around
gemdozer
Posted: 08 Aug 2010 at 3:23pm |
I should have some bolts 086835 and some time they are not easy to remove
and I have to check tomorrow morning for make sure.
Danny NM
Posted: 08 Aug 2010 at 5:14pm |
Thanks you guys. a little good news. worked on it today still would not give up it's grip. if you find one please email me or call 505 425 6265 Danny
gemdozer
Posted: 08 Aug 2010 at 6:45pm |
Did you remove the smaller bolt each side off the guard and
try too pull the top guard in front side sometime it loosen
the big bolts from the guard and frame
gemdozer
Posted: 09 Aug 2010 at 6:32pm |
I check today but no chance to get my hand on the guard bolts maybe
they ben sold and I will recheck tomorrow again
Danny NM
Posted: 21 Aug 2010 at 8:18pm |
Hello everyone The bolt and nut finally parted ways. A welder,pipewrench,bottlejack,slug,sledgehammer,torch and alot of dreaming i was on some beach somewhere it gave up it's grip. So now maybe like Dadsdozerhd5b said it will run again. thanks for the help Danny
