Exhaust manifold torque specs
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Topic: Exhaust manifold torque specs
    Posted: 26 Dec 2017 at 2:23pm
Happy New Year friends or at least close to it.
Replacing the exhaust manifold gaskets and in the service manual there is little to no information on the exhaust manifold. Are the nuts torqued down or just tightened?
If torqued down how many pounds please.
Thank you.
Morten.have View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morten.have Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2017 at 2:59pm
Now I’m jealous at you jerry. I will give my right arm to be at your stage right now. Because I’m still just looking for a manifold..
I can’t help you with turque spec, but use the standard bolt/tap spec card
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2017 at 5:41pm
Hahahaha . If I could find you a manifold I would a happy camper. Most of my work do far is routine maintenance work and cosmetics.
You and others in our forum do such extensive work on engine and tranny internals that I get humbled. If I ever want to be reminded how much I don't know I only have to look up posts from you, AC Mel, Ricky, Cal and CO and I am reminded that nothing major better break.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2017 at 5:43pm
Let's not forget DMiller. He has helped several times now.
Ferdinand View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ferdinand Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2017 at 5:50pm
"Tighten but do not overtighten". That was the torque spec. for a Nissan I used to have.
What size bolt or stud are we talking about?
Mathew 7:14
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2017 at 6:31pm
i was thinking 45lbs, and i swear it is in the manual but maby i am imagining.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2017 at 5:23am
I've looked and can't find it. Not saying it's not listed somewhere but I couldn't find any reference to it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2017 at 5:46am
I could be remembering from our 8550 tractor overhaul or just making it up, who knows lol.  I have an 8550 service manual i can look in it but its at dads place and we are traveling to inlaws today.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2017 at 6:15am
If 7/16 SAE 45ft.lbs. would be good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2017 at 7:29am
Thank you DMiller and Cal for the input. I think 45 will be my choice.
Thank you both.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2017 at 12:06pm
they are 1/2 NC
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2017 at 2:08pm
Would not take those over 50#
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2018 at 10:34am
Hello group
I pulled out my shop manual for my 16dc to look up to see torque specs. Found that the torque spec for the exhaust manifold nuts on the 16000 engine are more than we were discussing in this string of messages. I am posting the pic out of the manual. They are saying 85 to 95 pounds. That seems pretty high to me but that is what the manual says.
Any comments my valued advisors?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2018 at 10:42am
I may have figured it out but please correct me friends.
My HD16DC engine plate says it is "Engine 16000 HD 16C"
                                                       "Engine #4393
My tractor serial number as listed on back of tractor under the fuel tank is Serial # 5272.
So by reading this paragraph below from the Service Manual, my tractor is NOT the 844 but the 16000 and as such the torque setting is more than the number listed above that for the 844 which is at 45 to 50 pounds per some of your previous statements.
Am i correct. See note below.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2018 at 11:12am
you have 16000.  844 is also the CU of the 16000 but was the designation for lanova engine.  basically the same engine except for head design and fuel injection parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2018 at 12:02pm
Thank you Cal. Sure a big difference in the two torque specs for the exhaust manifold nuts.
This page was generated in 0.052 seconds.
