WD45 Traction BoosterIssue
SLB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLB Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Traction BoosterIssue
    Posted: 10 Feb 2018 at 10:55pm
Hoping for some advice.  I replaced a 70 year old traction Booster with a new gauge.  The indicator pointer bounced around like crazy then fell of inside the gauge itself. I returned it as defective and got another one,  I finally got around to putting in another one and it did it again.  I left it in and finished plowing where it started leaking from the glass. Anybody have or heard of this issue before? A'm I getting bad new gauges? Do I have an hydraulic issue? Any advice would be appreciated.   Thanks, Steve
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 6:52am
Where are you getting the bad ones from?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 7:14am
SLB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLB Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 4:58pm
Steiner
Reindeer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 5:01pm
Tonys Tractors
SLB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLB Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 5:04pm
Does Steiner tends to have bad gauges?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 5:07pm
Nothing wrong with your hydraulic system, unless it's going over 3700 psi.  If I was installing one, I'd probably bleed air from the line after installation of the gauge.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 5:07pm
Just make sure you have small diameter tubing to the gauge as it helps dampen the pulsations (i.e. like water hammer).
Charles (KY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charles (KY) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 5:17pm
I have installed 3 that came from Steiner and the needles fell off of all three.
SLB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLB Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 7:06pm
Thank You, For your input.  Thats exactly what I needed to now.  Steve
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2018 at 8:12am
I had the issue. Bought one and about 20 hours later the needle fell of. another 10 hours and it filled with fluid and popped the glass. It doesn't matter where you purchase from. They are all made in the same factory. Either replace your's with a 5000PSI liquid filled gauge for $20 like I did, or get your original rebuilt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2018 at 8:27am
These new ones are all made in China.  They aren't worth the aggravation.  There are SOME that are old stock that were made in the US, but you've gotta ask the vendors on here.  NONE of these China ones are any good.
Do as Tuck says and just install the simple pressure gauge.  That is if you're just looking for one that WORKS and not for a parade vehicle.  I put one on my WD45 3 or 4 years ago and it's still working great.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2018 at 8:32am
Now I know if I ever have a WD45, don't toss the old gauge!
SLB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLB Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2018 at 10:58am
Well,  I both use my tractor and show it so I'm thinking rebuild it?  Anyone know where I can do this? Can I get a kit? Any comments appreciated.  Thanks , Steve
SLB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLB Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2018 at 11:02am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2018 at 12:15pm
I think user oldoug on here used to rebuild them
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2018 at 2:53pm
Yes, Matt Folkers aka Oldoug repairs them.  I've got a couple 3 laying around that I need to send to him for fixing up.  I don't know if you HAVE to send him the old one, but I think so.  Otherwise I think he charges you more with no core.
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2018 at 9:14pm
Does anyone know for sure if Oldoug still repairs them? I wish he would chime in on some of these post. I looked his name up once, but I'm reluctant to just PM him out of the blue.
SLB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLB Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2018 at 9:26pm
I am waiting on a response.  If I here something I will post something either way.  Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2018 at 9:17am
There was another guy too posting on here not long ago that also repairs them, but for the life of me I can't remember who.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2018 at 9:44am
I', not all that worried about traction booster gauge working, I have been on the seat of WD/WD45's for years (more than we need to talk about LOL) and don't even look at the gauge working ground, you can fell what's going on with your rear-end so if it was me just get a non-working gauge and look at it. lol
Tom IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom IA Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2018 at 10:46am
Matt did one for me about year half back, nice job
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2018 at 12:58pm
I got a rebuilt one at the Allis Connection show in Amana. It's been a few years, but I think it was Norm Meinert that had them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2018 at 1:47pm
It's your choice. Personally I'm not worried about someone hunting me down at a show to tell I have a pressure gauge instead of a traction boost gauge.
Here's a similar discussion form a few years ago with my favorite quote from CTucker.
I said I didn't want the correct police after me and Charlie says "Ya, but with the cost savings, you can still afford the fine"
Honestly you don't need it. Some WD's didn't even have a gauge. It is kinda fun to watch though and I think a standard pressure gauge is cheaper than a non-working Allis Gauge.
I bought a Valley gauge and even has a persion orangish color too it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2018 at 7:35pm
Just a dumb question, How does a traction booster gauge differ from a pressure gauge? As long as I can remember mine has never worked.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2018 at 7:59pm
It's just a pressure guage without PSI markings. I think I have a couple on the shelf I removed. The 190 I pulled the tub guage and put a oil pressure guage in its place and the CA guage looked dorky on that little bracket sticking out from the steering post. I've never even looked at either WD 45 but they probibly don't work. I just put the lever in the middle when I plowed.
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2018 at 9:08pm
     What Don said.
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
This page was generated in 0.138 seconds.
