ca pedestal removal
kenbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenbob Quote  Post ReplyReply Direct Link To This Post Topic: ca pedestal removal
    Posted: 03 Feb 2018 at 4:06pm
Working on the steering slop in my CA. I followed the manual, got it off the tractor (2wheel) and got the pinion gear off.  The IT manual doesn't make it seem like a big deal getting the pedestal off the shaft after that, but I am not able to pull it off.  I need to replace the bottom seal or I wouldn't be messing with it, so I am not worried about destroying the seal if that is what it takes to get off.  I lightly tapped the bottom of the pedestal with a hammer and I also tried jerking it off from the top side.  I could use advice right now before I wreck something.  Thanks.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2018 at 5:40pm
The I&T manual tends to leave out most of the needed details. I have a CA (and others) shop manual on line at:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
 Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenbob Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2018 at 7:24pm
Thanks Gerald,
Way better than the it books.
Gerald, what part of Iowa are you at?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2018 at 7:28pm
My farm has Ames city limits on two sides, my home is about 10 miles from The Boondocks.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenbob Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2018 at 7:37pm
Gerald, I know those 2 seals are available from the dealer, but since you were so helpful, I would buy them from you if you have them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenbob Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2018 at 7:45pm
From Alton originally. Wife is from Marcus.  We live by KC now but go to Marcus every month to visit her sister in the nursing home.
