7020 coolant lines?
Blustery Knoll Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blustery Knoll Farm Quote  Post ReplyReply Direct Link To This Post Topic: 7020 coolant lines?
    Posted: 29 Jan 2018 at 7:30pm
What seals the steel coolant lines that connect to the oil cooler? I tightened the nuts and the leak didn't stop. I loosened the nut to see if it was a cracked flared end, but it's not a flare fitting. I only found a few pieces of rubber chunks inside the nut. Is it a rubber compression washer?
Related question. What's the proper coolant to use? If I drain it, I might as well put in new.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2018 at 9:26pm
Rubber chunk.Looks like a very short piece of hose. Do like Doc says and put in Cat extended life coolant.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blustery Knoll Farm Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2018 at 9:46pm
Is that a dealer part?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2018 at 7:25am
Yes, get it from an AGCO dealership.  What ever happened to your engine HP complaint ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blustery Knoll Farm Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2018 at 9:30am
Thanks. I haven't dealt with that yet. My local independent mechanic told me to drive it to his shop and run it on the dyno, but I've not had a chance to get it up there yet. It's either been way too cold, then it gets foggy when it warms up. Neither being good for a 25 mile tractor drive. Hoping to get it up there next week.
This page was generated in 0.065 seconds.
