d17 was delivered tonight
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Topic: d17 was delivered tonight
    Posted: 04 Dec 2017 at 6:07pm
I recently purchased a d17 with loader and backhoe and it was delivered tonight.  The motor is stuck so I put some atf, pb blaster and fuel oil mixture into each cylinder.  bit late for pictures but I'll try to get them tomarro
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2017 at 8:50pm
Don't be in a hurry to free up the motor.  Let the juice do its thing, keep adding to it as well.  If you drop the oil pan, eventually you will see some drops form under it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2017 at 4:22am
it's sitting outside and after today the temps are going to drop, so no big hurry on getting it unstuck.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2017 at 7:21am
Looks like you got a nice rig,if you need parts i have a D17 power unit I picked up a while back turns over haven't tried to crank it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2017 at 1:00pm
Here it is, it needs some attention.  some hoses, a left front rim, the left rear rim needs fixed, etc. + the engine unstuck.
This page was generated in 0.071 seconds.
