hd5b dozer progress
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Topic: hd5b dozer progress
    Posted: 12 Sep 2012 at 4:59pm
i am making progress. i got the axle in, track frame and tracks back on but then had a setback. the right steering clutch was very hard to pull back and needed alot of brake to get it to stop. i had noticed last year while running it that i had mice living in it as they came out when i drove it. i thought i had gotten rid of them but i guess not. so, i put it in the shop and started tearing into it. lo and behold, mice were in there. the worst part of the clutch removal was removing the brake pins. neither would come out so the hot wrench took care of them. luckily, they did not get to the center of the clutch, just outside in the compartment but their pee froze up the slide for the throwout bearing and making it hard to pull back. at least i can reuse the clutch and drum. i am making stainless pins to stop the rusting. i will upload pics soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 5:14pm
here are some pics
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 5:17pm
still trying to figure out the multiple pic thing.  :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 5:18pm
one more. still can not figure out how to comment on each pic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2012 at 10:31am
Seems the dang mice make a mess of everything , as the 3/4' hole for the case drain is on the bottom I am unsure of they come through that or come through by the hole into the case for the brake rod.
 Dang things end up into everything and it doesn't take them long to move in whan something sets for a few days.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2012 at 10:35am
i hate them meeses to peeses!
I am still confident of this;
Wait for the Lord;
shanksmare View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shanksmare Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2017 at 1:07pm
So you cut the pin out and pulled the clutch out with the brake band? Mines stuck too so I guess that's my next step.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shanksmare Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2017 at 2:52pm
I ended up taking the 4 bolts out of the brake band bracket because the brake pins wouldn't come out and have all the clutch bolts out, seems pretty solid to the drive wheels yet, mine didn't look nearly as rusted as yours so why wont it come free?
