Replacement SW gauges
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Topic: Replacement SW gauges
    Posted: 23 Nov 2017 at 7:58am
Happy Thanksgiving everyone.
Question. If I replace some of my original HD16 gauges, do I need to take into consideration the 24volt system?
No gauge lighting but was wondering about any electric requirements.
Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2017 at 8:06am
Depending on what type of sending unit is used - if electrical - YES needs to be voltage correct , amp gauge doesn't care - mechanical heat or pressure no problem
 You may need a resistor in feel voltage if using 12V gauge .
 Most hour meters don't care on voltage either as have range they operate in
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2017 at 8:24am
Gauges on Allis that old should be mechanical.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2017 at 6:14pm
Thank you Coke.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2017 at 6:15pm
Good point DMiller. Thank you
This page was generated in 0.085 seconds.
