200 injection pump removal
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: 200 injection pump removal
    Posted: 05 Nov 2017 at 9:11pm
Felt bad on hijacking over posts.
I'm wanting to pull injectors and injection pump in hope to send to Ed to rebuild.
The other posts on 185 is nicely explained but is different then 200. The 190 would be similar but didn't want to hijack that post.
Was wondering what helpful tips anybody had for this job. Thank you for any help you have
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2017 at 9:24pm
PM ED. He can walk you through it and you'll get correct advise. I know what on a 220 but it may be different.
Edited by SteveM C/IL - 05 Nov 2017 at 9:24pm
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2017 at 7:59am
Really the main difference from the 185, is the oil cooler and turbo lines. Disconnect as few as needed to get the pump out. I take the front access cover off and that allows me to slide the gear and shaft forward enough to get the pump out of the tight spot it's in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2017 at 8:07am
Ok Ed. Is there a tool for injectors or will they pop out easily
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2017 at 8:20am
prybar, and carefully pry them out after taking all lines and bolt off. Sometimes they can be rusted in pretty bad, other times they slide right out. Make sure there's no copper washers down in the holes in the head. Even if they come out with the injector, look down the hole. I had one tractor here that had 3 washers in one of the holes! There is only supposed to be one in each hole. lol!
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2017 at 8:44am
Make sure you take photos of the injector lines before anything is removed.
 Photos of the disassembly process are extremely handy during assembly.
 Clean it very well before starting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2017 at 11:01pm
Ok thanks. Gota get it up and pressure wash it and get onto it. Thanks for help
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2017 at 7:33am
always remember to not pressure wash the injection pump while it's running. The cold water can cause the head to seize. Especially when it's really hot from working, and the water is cool. Has even occurred when driving in deep water.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2017 at 9:12am
Ok thanks Ed
This page was generated in 0.180 seconds.
