|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| Gleaner m2 |
| Post Reply   |
| Ben s   Silver Level     Joined: 16 Jan 2015 Location: Ontario Canada Points: 61 |  Post Options  Thanks(0)  Quote  Reply  Topic: Gleaner m2 Posted: 01 Nov 2017 at 8:10am |
   A friend of mine is selling his father in laws m2 I'm interested in purchasing it what are common things to look for when purchasing one and would this be a good combine to start with I have little experience with combines Edited by Ben s - 01 Nov 2017 at 8:11am | |
| nick121   Silver Level     Joined: 13 Apr 2016 Location: ontario Points: 322 |  Post Options  Thanks(0)  Quote  Reply  Posted: 01 Nov 2017 at 8:50am |
   Hey Ben,  I recently bought a M2, I'm not an experienced combine operator/ inspector but I usually look over the general condition like wear on augers, check the straw walkers for play in the wood blocks, check grain pan for holes. Most machines bin has rotted out by this point, I check to see how they repaired it, seen everything from tin metal off the side of a barn to spray foam, to a nice professional looking job with galvanized or stainless riveted in place.  Check sprockets to see how they are worn, My F2 has some very sharp sprockets in need of replacing. Is it gear drive or Hydrostat? My M2 is hydro and I haven't used it in the field yet but I already like it. Any heads with it? | |
| Lonn   Orange Level     Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |  Post Options  Thanks(0)  Quote  Reply  Posted: 01 Nov 2017 at 10:37am |
   See if the leading edge of the cylinder bars are nice and squared off or are rounded. If rounded check to see if they have been reversed. If not been reversed then you have a new wear surface to work with. | |
     -- --- .... .- -- -- .- -.. / .-- .- ... / .- / -- ..- .-. -.. . .-. .. -. --. / -.-. .... .. .-.. -.. / .-. .- .--. .. ... -  Wink I am a Russian Bot | |
| wekracer   Orange Level     Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1590 |  Post Options  Thanks(0)  Quote  Reply  Posted: 01 Nov 2017 at 10:43am |
   As the others have said already. Chains and sprockets and cylinder bars. You can run into big mines if you end up having to replace cylinder bars. We always kick them in gear and do a walk around and look for anything unusual. Also check warning lights. If they all work that’s a good sign. I also like to see working ac.  We have an L2 and it is an excellent machine. | |
| Ben s   Silver Level     Joined: 16 Jan 2015 Location: Ontario Canada Points: 61 |  Post Options  Thanks(0)  Quote  Reply  Posted: 01 Nov 2017 at 11:02am |
   Thanks guys I'm not sure if it's gear drive or hydro it comes with a grain head what would it be worth if it's in ok shape?
| Ray54   Orange Level Access   Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4760 |  Post Options  Thanks(0)  Quote  Reply  Posted: 01 Nov 2017 at 11:36am |
   In my mind the weakest part is the drive for the walkers,grain pan,and sieves. Over the years the key ways ware on the top beater shaft. Causes the grain pan and sieve to not shack even on both sides,will cause them to break. Did not watch mine close enough and broke the pan. To check make sure the sprocket on the right side of upper beater shaft is not loose. Also watch the chaffer at low speed and make sure it dose not move side to side,only back and forth. | |
| HARVESTMOONPULLER   Silver Level     Joined: 12 Oct 2009 Location: NW Ohio Points: 273 |  Post Options  Thanks(0)  Quote  Reply  Posted: 01 Nov 2017 at 9:28pm |
| As others have said quality of grain bin repair will give a little insight as to how the rest was cared for. Also check the bottom of the bin on the outside right before it gets to the swivel for the unloading auger. A lot of those are rotted out and ive yet to see a repair that was up to my standards including mine lol check sprocket teeth and make sure their not too sharp. Also see if ground speed, cylinder speed, engine rpm tach is working properly. Those sending units can be pricey. Also check reel speed and see if reel speeds up and slows down. | |
| joepro91   Bronze Level   Joined: 25 Oct 2017 Location: Ashland Ohio Points: 16 |  Post Options  Thanks(0)  Quote  Reply  Posted: 02 Nov 2017 at 2:50pm |
   Just to add.... I just bought an M2 this fall also. Many guys have told me that an M2 with a black engine and tan is a more desirable machine then the black interior and orange engines. | |
| GM Guy   Orange Level   Joined: 31 Jul 2012 Location: NW KS / S.C. ID Points: 1985 |  Post Options  Thanks(0)  Quote  Reply  Posted: 03 Nov 2017 at 1:43am |
   Condition is a big factor on a used combine, after that its just desireable options like a hydrostat and the variable speed header drive. IMO get at least a 78 or up, preferably a 81 or up, with the hydro and you will be doing good. | |
     Gleaner: the properly engineered and built combine. If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help. | |
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
