B liner O.D.
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Topic: B liner O.D.
    Posted: 21 Oct 2017 at 8:45am
Can someone with a calipers and a liner out of a B engine do me a favor? I need to know the O.D. of the bottom of the liner. Thanks much.
The mechanic always wins.
SteveC(NS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2017 at 11:20am
Marv, I measured a brand new liner as 3.678 at the bottom and 3.712 up just before where the O-Rings go.
I also checked a used (but still usable) liner and it measured the same.
Hope that helps.
Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2017 at 2:26pm
Perfect, thanks a lot!
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2017 at 4:01pm
Would these numbers be the same for my 1938 B, 1.9ltr - 116.1ci engine?
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2017 at 4:14pm
Prior to 1943 116 cu.in had 3.25 dia. pistons, 3.5" stroke
1943 and later 125 cu.in had 3.375 dia. pistons, 3.5" stroke
Not sure about the liner O/D's.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2017 at 4:53pm
I was thinking I would like to cut a sleeve puller disk.
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2017 at 5:16pm
That's what I need the OD for. I gave a machinist pal some scrap metal to make pullers for both a WD sleeve, and a B sleeve. But, the other day I put the liners in the B and never measured the bottom, and it's impossible to get to now!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2017 at 8:58pm
you can take NEW oversize bore sleeves and put in a 116 inch OR 125 inch block....... so the blocks have the same bore for any sleeve. ...   3 1/4 , 3 3/8 , 3 7/16 overbore
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2017 at 10:47pm
What would be the recommended disk diameter be for pulling 116ci B sleeves?
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2017 at 9:33am
The best pulling disk would have a shoulder turned on it to match the sleeve bore so it stays centered and the outside diameter less than the outside diameter of the sleeve.
Gerald J.
