fixing allis 2500 disc
nick121 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Topic: fixing allis 2500 disc
    Posted: 13 Oct 2017 at 4:17pm
I am replacing a few blades.. 3 short spools were broke. And a bearing was gone.
Boy are discs expensive with blades being $54 for a 22 inch.
Just a question on the bearings, They sell offshore bearings for $26 or better ones for $56.. are the more expensive ones worth it?
Also, any tips on getting them tightened? I currently use a pipe wrench to grab onto a spool then use a big ratchet or cheater bar to tighten the nut.
Just fixing what needs it right now but would like to do a full rebuild at some point, pretty good disc but it's 25 foot and a bit much for the old 7040
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2017 at 6:56pm
Tighten with 1" impact
joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joe Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2017 at 8:01pm
A 2500 shaft isn't real big, but typically when tightening a disc nut down, I'll use an 8' bar on either end. That may be a bit much for a 2500, so a 6' bar may be a better bet. Even a 1" impact is barely enough, and I wouldn't do that personally. I feel that a lot of the impacting is lost through the long shaft. A 1" impact has a ton a hit, but it's not all tightening the nut.
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2017 at 8:27pm
I've wondered about the bearings myself. We use as cheap as I can find, bought from eBay last time.
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2017 at 8:32pm
According to the 2500 manual, they need to be tightened to 750 ftlbs. Take 750/your_weight, gives you the cheater length.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2017 at 9:01pm
Everything has to be clean as you put it together,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2017 at 9:13am
thanks for the replies. I wire brush everything/ grind any rust between blades/spacers etc. I replaced a blade earlier in the season and it stayed tight, thanks for letting me know how much torque they are supposed to have.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2017 at 10:22am
Any time we tighten a disc gang of any kind we use a slug wrench. Always have been able get 1/2 to a full turn on what I can get with my 225-240 butt on a 4 foot cheater. I think Shoup has a special washer that helps maintain tension.   My Sunflower came used with it. Saying you put a 1" impact on it doesn't mean much.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2017 at 11:13am
I use the gang wrenches from Allis. They work very will as they are made just for the job. They are about 5' long and fit perfectly on both ends of the gang shaft.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2017 at 8:49am
Any body run notched blades on the front gangs and plain on the back? thinking about replacing all the front blades.. back are still good almost full diameter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2017 at 11:01am
Ask that question on Agtalk in the past the replies for notched aren't very favorable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2017 at 12:29pm
Notched won't run as many acres before they are worn out and are easier to break in rocks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2017 at 3:33pm
if you put new blades on, move the ones from the back to the front, then put the new ones on the back.
