653 Final drive
sparkchaser221 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparkchaser221 Quote  Post ReplyReply Direct Link To This Post Topic: 653 Final drive
    Posted: 19 Sep 2017 at 9:13am
Allis Chalmers 653. My right side final drive housing cracked and took out the pinon gear. Does anybody know where I can get a final drive housing or a carriage assembly? I am located in Georgia. I also am looking for a pinon gear.
650, 653, 655
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2017 at 9:34am
This is on ebay now, located Century, AL
Big Jim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Jim Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2017 at 9:38pm
I have a case setting in my shop. I can probably help with ever thing you need.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2017 at 9:47pm
That one on Ebay looks pretty good if you have the parts to fix it.
I see someone paid $3,450 for that Ebay one.  Nearly a grand more then I paid for one that runs!
Edited by JohnCO - 29 Oct 2017 at 12:17am
Allis Express participant
pinball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2017 at 6:37am
Do a search on the internet. that's how I found mine fOR my H4 which I think is the same. Get your pocket book ready. Don't be alarmed when you find one cause there definetly proud of them,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2017 at 8:37am
Watch the outboard bearing casting machining for bearing - that area is a weak spot in case and many have been repaired satisfactorily - but lot of cases with damage are still out there  - and for that gear - bring lots of money as it's expensive - just like axles and the drive gear. been there / done that .
 Had both cases machined to accept a steel insert to hold the Timkin bearing cup for the axle . went through 4 axles on my machines before it got traded in .
363ford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 363ford Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2017 at 7:06pm
Big Jim I sent you a message
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2017 at 3:50pm
It can be repaired by a good machine shop that specializes on heavy repair - I had a truck machine shop that does large transmissions and rear truck axles do mine on the HD4 as well as reinforce the ones on my FD5
This page was generated in 0.305 seconds.
