F gleaner motor
Tom b 45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom b 45 Quote  Post ReplyReply Direct Link To This Post Topic: F gleaner motor
    Posted: 15 Aug 2017 at 12:13pm
I hot a chance to buy a gas sin cylnder motor out of a combine that got in a wreck. The motor is seems good but I am thinking about buying it for the exhaust manifold I know it's not a Chevy motor but my question is are all the blocks the same ie 2400 2800 my 190 xt is a 301 ci not sure on the motor sizes will it fit ? Thanks for any help.
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2017 at 5:45pm
Early F gas is a 262,it will not fit a 190XT, later F gas is 292 chev,  Diesel F has the 2800, 301 cu same block as 190XT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom b 45 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2017 at 7:01pm
Thanks well that shot that deal but what about a wd45 could i put it in one of my wd45 I know I would need to length the side rails and work over the hood I can pick it up for 200 hate to let it go.if it's a 262 that is.
ACjack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACjack Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2017 at 8:14pm
Look at the LH side about midway and see if it has a cover plate. At one time the G2800 & D2800 shared the same block. I believed that the bolt pattern and flange size is the same as AC Delco gasoline fuel pumps.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2017 at 10:03pm
If it is a 262 AC motor, and if you can find a WD45D flywheel and adapter plate, it will go in your 45 with some other work.    MACK
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2017 at 12:15pm
Early 1968-69 F (serial # 1001-9000) have the G262 93hp engine.
Later 1970-76 (serial # 9001-36200) have the GM292 101hp engine.
You'll find the F machine serial # plate on left side under engine ladder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2017 at 12:21pm
FYI - Early 1968-69 gleaner G (serial # G/GH & G1001-12200) offered the AC301 G2800 105hp gas engine.
This page was generated in 0.101 seconds.
